diamondred
Onan Carburetor adjustable main jet
diamondred
I have a Wheel horse 518 auto with an Onan engine. Has anyone modified their carburetor to use an adjustable main jet? Or.. is there an adjustable jet kit available?
Thanks
boomers_influence
diamond
 please list the 146-xxxx #  from the side of
the carb, on the throttle side.
then i can tell you if yours will accept it.
WHY, do you want the adjustable main jet?
boomers_influence@yahoo.com    651 437 2826
thank you. boomer ( the used onan engine parts guy )
diamondred
Its under a tarp right now with 5 inches of snow on it, and not gonna have a number anytime soon. I can tell ya its on a '88 518 auto, which is going to be converted to an 8 spd in the spring.  Winters are below zero and Summers are in the 90's.... I want to be able to adjust it.
diamondred
Well boomers, here's all the numbers available that are on the carb
also found this on the internet .... seems there was a kit available at one time (9)
post-12532-0-70652100-1425745242_thumb.j
post-12532-0-09484100-1425745255_thumb.j
post-12532-0-73903300-1425745370_thumb.g
Edited by diamondred
diamondred
Ok,so I found the p/n for the jet kit I need. It is 146-0327. Which is #9 in the posting
boomers_influence
diamond
i do stock that kit. ( 146-0327 )
WHAT, actually is the model and spec# of your engine?
i do have in two NOS carbs of the same # as yours.
they have the LARGE venturi, ( # 238 ) but a SMALL main jet ( # 127 )
usually a # 238 will be # 130 to 134 main jet.
please call 651 437 2826
thank you. boomer
motodinosaur
do you still have any of those kits available
boomers_influence
moto
i believe that i may have one yet.
these kits were mainly for gen sets in motor homes.
if they traveled across country it would come in handy.
because of elevations from below sea level to 6000 feet.
for the  average garden tractor they are NOT needed.
651 437 2826 M-F 10-7 S-S 12-6 cent time.
thank you. boomer ( the used onan engine parts guy, also NOS and new )
motodinosaur
thanks boomer  i'll call you tomorrow I live in Sheridan Wyoming the tractor might go from 3900 feet to 6000 feet depending on job to get done
boomers_influence
moto
i will need the 146-0xxx # from the
throttle shaft side of the carb.
they will not fit the later model carbs.
thank you. boomer
