brian pa 2 #1 Posted February 22, 2015 I'm having trouble locating the drain plug on the 700 pump on my 1985 314a. I see a large bolt behind the fan on the bottom of the pump so not sure if that is it? Any help is appreciated. Thanks Brian Share this post Link to post Share on other sites
boovuc 1,090 #2 Posted February 23, 2015 Brian, I never had a working Eaton 700. Just one that was bad without the pump installed that I later parted out but I always thought the 700's were a closed system. Share this post Link to post Share on other sites
shallowwatersailor 3,213 #3 Posted February 23, 2015 (edited) Here is the Eaton catalog sheet for the Light Duty Transmissions. I can't remember which drawing is for the version that Wheel Horse used. It is either page 7 or 17 for the 700 drain plug. http://www.eaton.com/ecm/groups/public/@pub/@eaton/@hyd/documents/content/pll_1616.pdf Edited February 23, 2015 by shallowwatersailor Share this post Link to post Share on other sites
brian pa 2 #4 Posted February 23, 2015 Thanks guys I was thinking too of the possibility of it being a closed system. Thanks for the manual ill take a look. Appreciate it. Brian Share this post Link to post Share on other sites
