motor12
need torque settings for 5003 trans case
motor12
What are the torque settings for the 1/2 in bolts on the case of a 5003 RJ58 trans, I did a search but no luck. Thanks
Racinbob
Good question. All I see in the manual is "torque all bolts on both side covers evenly". That's what I did and just went by feel. I did use thread sealant on them because the threaded hole runs all the way through. Maybe one of the transmission gurus here will have a number for you.
stevasaurus
Bob's right.  I just snug them all first and then go around and tighten "maybe" another 1/4 to 1/2 turn.  They are easy to strip, and you do not want to do that.  Having them all about the same is more important.  :)
motor12
Thanks, didn't think about the thread sealer but I will use it.
Racinbob
I didn't think about it either motor. Not until I had a tiny bit of seepage from a couple of them. It may have been attributed to using stainless bolts :confusion-shrug: I cleaned the threads real good and a little Loctite 592 did the trick. :dance:
