motor12
removing bronze bearings from 5003 case
motor12
Any tricks or special tool needed to remove bushings from my 5003 trans. Thanks
stevasaurus
I just find the thinnest edge, use a small, flat blade screwdriver...hammer the blade in between the bronze and the steel.  Sometimes it will cut, other times it just dents in.  Either way, it will soon loosen up and you can pull it out with needle nose pliers.  It is really pretty easy.  When you put the new one in...use a piece of 2 x 4 on top of the bronze and tap with a hammer.  You will probably have to hone the bronze a little to fit the axle.  :)
  • Like 4
