motor12 367 #1 Posted February 20, 2015 Any tricks or special tool needed to remove bushings from my 5003 trans. Thanks Share this post Link to post Share on other sites
stevasaurus 22,883 #2 Posted February 20, 2015 I just find the thinnest edge, use a small, flat blade screwdriver...hammer the blade in between the bronze and the steel. Sometimes it will cut, other times it just dents in. Either way, it will soon loosen up and you can pull it out with needle nose pliers. It is really pretty easy. When you put the new one in...use a piece of 2 x 4 on top of the bronze and tap with a hammer. You will probably have to hone the bronze a little to fit the axle. 4 Share this post Link to post Share on other sites
