baerpath 517 #1 Posted February 20, 2015 Need to pull the cam and replace it in a 25hp Command. Right now it has a cam from Joe Faircloth in NC. Ran ungov down there. Have to run 4500 gov up here. Has all the normal stuff done that you would expect for the class and supposed to be running at 15-1 comp on 120 octane. Any recommendations of cams or profiles Share this post Link to post Share on other sites
Deere Hunter 54 #2 Posted February 20, 2015 Duane, What is the specs on the cam your pulling out? Is it a roller cam? I would talk to Hackman or Lakota on the cam. The cam you would need will probably be in the 230-240 duration range. Lift on the cam will depend on what valves you currently have, stock length or .300 longer? Share this post Link to post Share on other sites
Raider12puller 1 #3 Posted April 4, 2015 Do you have Hackmans number? Share this post Link to post Share on other sites
