indywheelhorsenut
Yet another question about snowblower interchangability
indywheelhorsenut
I see a decent looking snow blower #79263 and wondering if it will easily fit either my 1974 C-160 or my 2000 314-8?
Your input would be appreciated.
indywheelhorsenut
Never mind.... I found my answer.... looks like it is not worth messing with....
can whlvr
ya I would think where you live there will be lots of horizontal shaft throwers
  • Similar Content
    • sraces
      By sraces
      I purchased my 314-8 new in February of 1996.  It's been a great tractor.  But a few years ago I had landscaping done and contracted for lawn service.  So the tractor has been sitting in the garage for a few years.  Bought a new battery.  It cranks hard, but won't fire.  Probably needs the fuel lines or carburetor cleaned.  It also needs the clutch shock replaced.  I have the new shock and belt.  Just haven't gotten around to replacing them.  Deck is in excellent shape with new spindles before I parked it.  Comes with the nice pull behind spreader that has only been used twice.
      Thanks for you consideration.
    • HyperPete
      By HyperPete
      JD LX-178 with Kawasaki 2 cyl water cooled engine.
      Great shape except for the front hood.  Cracks have been patched, and hinges on the hood itself are broken.  Hood sits fine, just does not open & close properly
      NO DECK!
      Includes (4) John Deere suitcase weights, a John Deere "maintenance kit", and rear chains.
      Well maintained.  Snow blower presently not mounted.
    • Spottedeventer
      By Spottedeventer
      Hi! The shafts of my fathers old 314-8, deck number 73449 have worn to the point the blades don’t stay secured. I’ve struck out tonight trying to find a part number. If anyone can assist, I would greatly appreciate it.
      thank you,
      Patricia
    • wh315-8
      By wh315-8
      10HP with 42” blade, C-85 w/cab & 42” Snow Blower, 315-8 w/Ark Loader. Ready for some snow ❄️. Last year had up to 14” in Ohio.
      Snow cab windows were fogged up bad and I used MeGuires PlastX, this stuff was easy, apply like wax, rubbing it in and wipe off, amazing how it cleared that plastic window up.
    • colbyeast
      By colbyeast
      Looking for someone in the Northeast (New England area) that can look at my Kohler Magnum 14 ( over 2000hrs
      )had rebuilt about 2 years ago (very little hours after rebuild)it's now blowing white smoke and going through oil, (checked breather :ok; cylinder has carbon build up no wear on cylinder wall) Could it be rings gone?Also needs carb work (throttle linkage very loose) Thanks in advance
