rustoleum appliance expoy questions
By
jm46322, in Restorations, Modifications, & Customizations
Similar Content
By PWL216
Are there aftermarket front rims available for C Series tractors? I have a 120 and a 160 that need front rims… thx.
By r1jakecfd
Hi Guys,
I just bought some Carlisle Turfmaster 24x12-12 rear tires to replace the 23x8.50-12 tires I have on there now. I was wondering which rims I should buy to fit these bigger tires. The charts say an 8.50 width rim but should the offset stay the same or does it need to change? Any other dimensions I should be concerned about?
Thanks in advance.
Hope everyone is healthy and well!
John
By 1990520H
What is a good replacement rim for the fronts since you can no longer get the stuff from Toro. Been looking. Not much luck. Any help would be greatly appreciated.
By old5foot
I have an 1989 312-8. The Owner's Manual shows a color photo/picture of a WH with silver/gray rims. The WH has silver/gray rims now, but it definitely is not the original paint. I am redoing the rims (sandblast and repaint) and I would like to repaint with as original a color as possible. I would appreciate any information available. Thanks Old5foot -
By old5foot
Anybody had any success mounting Kenda Terra 502 tires on 7.5 x 12 Wheel Horse rims?
Kenda says the tire needs a 8.5 x 12 rim. They spec. out as 23 x 10.5 x 12.
My 318 rims measure 7.5" from inside of bead to inside of bead. So they just might work.
Reason for all this being I have some steep slopes down to the lake. Yard has a toboggan run slope, a couple of 8 - 10 foot drops with flat areas in between.
Total drop of about 20 feet in about 100 feet. Plus the soil is Michigan sand. Grass is thin and the old original Carlisles just aren't cutting it anymore.
Looking for a more agressive tire for turf. Have read some goon reviews of the 502's on this forum. But not much detail on the rims they were mounted on.
Any experiences good or bad would be appreciated.
Thanks
Old 5 Foot
