SethL1984
New to me 520H
SethL1984
Ok Gents,
I'll be picking up a rough 520H this saturday; I was told it ran only a matter of months ago until it "lost spark". Being my first Onan, I'd like to know what you onan guys think I should look for! Possibly even a checklist
to run through once its home. I'm looking for any and everything! I'll be checking the system overall but I'm hoping for a few Onan tips.
Let the instructions and tips fly guys!
SethL1984
Also, wheres a good place to get mufflers from?
Shuboxlover
CONGRATS!!!!!!!!!!!!
Check.....fuses!!!!!....WIRING!!!!.....Ignition switch......I have a great used muffler if you're interested!!!
LOVE MY 520'S!!!!!!!!!!!!!!!!
Edited by Shuboxlover
boovuc
Shubox is correct for first off. If the PM said it lost spark, make sure it didn't lose spark because of a safety switch, ignition switch or bad connection first.
If it has no spark, check the seat switch, transmission neutral switch, PTO switch, parking brake switch, ignition switch connections. Check for a bad ground! Pay REAL close attention to the 9 pin connector between the battery and motor. Open it up and spray it with contact cleaner for now. Make sure the connections are tight. Look for burnt wires on this plug!
If you still have no spark, test the coil and then the ignition module located under the flywheel. (PIA). Do a search in the Electrical forum here on how to check them.
Once you have it running...............shut it off and keep it off until you first take all the tins off. Especially the rear cylinder and clean the cooling fins out and any grass stuck to the tins. With everything opened up, you should adjust the valves as well. (Very easy to do). Change the oil and filter the sparkplugs and buy a new gas and air filter for it.
I would also de-carbon the heads if I thought it was a sweet engine worth holding onto.
Congratulations on the 520!
ericj
i think you should just give it to me and avoid all the headaches :ychain:  :laughing-rofl:   check the onan service manual it will tell you how to check and what to check
eric j
HorseFixer
Congratulation's I have 4 of them in various stages of condition.  I have been through them from front to rear Including rewiring and rebuilding the engine.  They are a great tractor. I would follow what  boovuc says on the wiring. I suppose they can be intimidating if you cant read a wiring schematic.  Let us know how you come out on it.    :thumbs:
~Duke
SethL1984
Thanks for the info guys, I really appreciate it!
Keep it all coming!
JERSEYHAWG /  Glenn
Best of luck, cant wait for some pictures.
Glenn
boovuc
(Bob)....Duke did a conversion on one of his 520's where he mounted a remote oil filter. This is an excellent idea and opens more air flow through the rear cylinder and at the same time, should cool the oil better plus it increases the total volume of oil for the engine. He ran the lines out of the tins and made a little circular adapter plate to close the opening up. This also makes changing the filter easier and you don't get oil everywhere when you have to tip the filter to get it out of the small opening where it is in the stock position. (All pluses)!
Of all the mods I have seen on Onan powered Toro-Wheelhorses, Duke's remote filter is the best one in my opinion.
  • Like 3
SethL1984
It's a rough one...
motox25
Hey that one looks almost identical to one I restored last year! Rough, yes but a very solid tractor under all the rust and faded paint.
can whlvr
they just have to hack the hood :banghead:
Theroundhousernr
Looks like it lost a little more than spark... lol :ychain:   That sure is rough but I have seen alot worse turn into beauty queens. With mouse nests like that right near the bulk of wires, I would start looking for chew marks. I have a hood and some other stuff if interested. PM me. I am outside of reading.
     kyle
ericj
i would concentrate on getting the motor running first and see how that goes then start addressing the other issues once it is know if it runs good or not
eric j
SethL1984
Yea, its rough, but the price was right.
ericj - Motor if the first thing on the list!
Theroundhousenr - Surprisingly enought the wiring doesn't look to bad as far as I can tell so far! No corroded terminals and no chew marks yet! PM sent...
can whlvr - Tell me about it... He told me "they wanted to much for a new muffler, so I put one from a miller welder on it!..." I kept thinking, tearing up the hood was the trade off he chose for buying a cheaper muffler!? Oi...
I haven't really tore into it yet, I'm also reading posts on the hydro's my dad and I are 8 Speed guys so I new to the hydro arena. I'll keep you all posted on what I find.
And if anyone see's something in a photo please let me know!
ericj
the onan service manual on here as a down load will tell you how to check for spark, i also think martin started a thread on here that's pinned how to check the onans  if you can't find it pm me your email address and i'll email it to you good luck
eric j
JERSEYHAWG /  Glenn
Thats interesting and a great upgrade. Like you say, changing the oil is a dirty, messy affair. Big design flaw to me. Maybe Duke will pick up on this and post some pics on that conversion.
Glenn
Seth, you will get it in order, take your time. One step at a time. Good luck.
Glenn
bobert94
what a shame how some people destroy or try to destroy these things. makes a person sick!!!
bmsgaffer
I have a solid 520 hood from a 91 if you are ever looking to replace that one. Its painted black by the PO but there is VERY LITTLE rust, it is solid.
$75 + shipping (obo)
Edited by bmsgaffer
1977.d-160
I've had my '93 520H w/ a QuickWay loader for a four or so years now.  It is a great machine!  I'm really impressed w/ it's power & lift capacity.  Mine came w/ dualies, but after snapping the right axle (twice) I've opted for the less stable, but less labor-intensive single rear wheels.
As mentioned - I'd definitely focus on the mechanical stuff first, you probably don't want to be spending your $$ on lipstick, glitter & yoga pants when what she really needs is to hit the gym.   :banana-jumprope:
She may not be the prom queen at this point, but once the mechanical issues are addressed she'll surely put out...  :banana-tux:  and you can pick away at the cosmetics as resources permit.
  • Similar Content
    • 2drxploder
      By 2drxploder
      looking for a tiller for my 520h as well as some wheel weights. also maybe some good chrome hubcaps
      located in charlotte nc area
    • Rob R
      By Rob R
      So... I got cabin fever and against my best judgement, picked up from my brother a 520H Model # 4120OE02; Serial 1033076 (1991) that he got from a Friend who claim it ran but hasn't been used in years and was in dry storage. Included was a 48-inch triple blade mower in very good condition, total cost $250 ..... I figured that even if the tractor was no good the deck was worth the coinage....... and it had a good new battery....... So got it home fixed the one flat tire, replace the cooked fuse in the fuse holder. Cranked the engine over it cough a few times and then quit, was not getting fuel, replace the fuel line from the tank to the pump, pump not pumping, replace it with a B&S pump, cranked her over and she started right up ran and idled decent with no noticeable smoke. p.s. the hour meter is disconnected but you can tell she was run hard and put away wet but overall, in fair to good condition.
      So without doing anything else time for a test drive. It moved forward and backwards took her out into the yard got about 50 feet and the motor started laboring to me was like the transmission was putting a heavy load on engine, I tried to shift into neutral, but it wouldn't let me do that and then the engine bogs down and shuts off. Wait like 10 seconds start her up again and the issue repeats.... In all my years I have never had anything close to this issue hence my call for help.
      I did all the normal stuff trans fluid looks clean added some 10-40 weight to top her off, did not change the filter yet as I do not have one in stock.  You can start the engine without engaging the transmission and it will run fine until the cows come home..... put it in gear forward or reverse and it will go an little ways and then the load condition occurs, the engine loads up and is dragged down into a stall.
      Appreciate all your advice as this one has me stumped......
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • lsc1257
      By lsc1257
      I have a 1996 520H Wheel Horse for sale.  The tractor has just over 800 hours on it.  It comes with a 48 inch deck.  The deck is a 1995 and has over 1,500 hours on it, as it came brand new with my 312-8 that I sold several years ago.  This 520-H has the swept front axle so it can handle a 60 inch deck.  I just replaced the battery and the deck belt this summer.  The engine is a 20HP Onan and it starts right up but requires the full choke.  The transmission is an Eaton 1100-062, hydrostatic.  The deck is in rough shape but the spindles appear to be in good working order.  The right rear tire has some cracking.  The original operator's manual for the 520H is included, as is the original operating and maintenance instructions for the deck, plus the installation instructions for the deck.  Also included is a new PTO belt and several miscellaneous deck wheels and rollers.  Additional pictures available upon request.  Asking $500.
    • Joe Warren
      By Joe Warren
      Wheel Horse
      Service Tool Kit
      Onan Industrial Engines
      ON-420-0556
      Kit is missing oil filter tool, otherwise complete. Tools in excellent condition. Small crack in plastic case, bottom, middle.
      $129 plus shipping cost.
      Message me if you are interested in purchasing. Thank you. Joe
