JaredB
NEW HORSE!!
JaredB
Just got it home 3 days ago and since weather isn't very nice out for pictures all i can show is it in my cramped up garage... I will definitely post more pictures of it cleaned up and looking good this spring. Came with a 60" fab deck and i went and picked up a  42" single stage snow thrower for it today.
post-10400-0-16399500-1422155048_thumb.j
post-10400-0-25020600-1422155049_thumb.j
  • Like 5
Challenger
Congratulations Jared !
One of the best garden tractors of all time.
slammer302
Looks good!
AMC RULES
Nice score there...   :thumbs:
see the new decals our Vinylguy Terry just released?
JERSEYHAWG /  Glenn
Now your talkin. Best of luck. What engine?
Glenn
JaredB
522XI has the 22 horse kohler in it, smart steer, cruise control, hi lo transmission and 654 hours :D
shallowwatersailor
Nice tractor! Change the fluids (Mobil1 10W30 in the transmission), clean the power steering filter, and grease the fittings would be my recommendations. Also check the steering components at those hours as they do loosen. They are very capable tractors and it is nice to have the snowthrower now as well for the times lake effect snow hits. It looks like grey wheels so is it a 2000 522xi?
JERSEYHAWG /  Glenn
Ok.....522. I have the same. HECK of a rig.
Glenn.....btw. good luck with it.
JaredB
has gray wheels but model and serial have it at a 1999
  • Similar Content
    • Berco
      By Berco
      Hello all. My battery in my 520LXI was going out, the lights would come on but the engine would not turn over. I put a 1.5 amp truckle charger on the battery when i left for a 4 days trip. I come back and the same. I also noticed i left the key in the run position (the hour meter did not run). I swap out batteries and now the mower is completely dead. When i turn the key - nothing. I verify the battery it good (13.04v), negative is connected to the engine block, voltage is good on the solenoid side of the starter. I out the key to run and try to jump to see if i can start and nothing. Not even a spark. I have used this mover for years and has 500 hours. Could the ignition switch or brake switch be bad? The seat switch is jumped.What else could cause my mower to be dead? Thank you in advance.
    • gfullz
      By gfullz
      Hey guys! new wheel horse owner here. I picked up a 2001 523xi that came with a berco subframe. I happened to find a 40" compact berco that was hardly used to slap on it only I'm not sure where to start as there are no resources for this that I can find. I'm mechanically inclined, rebuilt the injection pump, injectors etc... as I purchased it non-running as it wasn't receiving any fuel to the injectors (it runs amazing now btw).
      so for starters I'm going to go out on a whim here and say that this will require the mule drive or "pulley box". and I've got the rest of the parts in the picture. The parts of the subframe that look to bolt up seem so narrow compared to the hookups on the rest of the tractor. Any help is greatly appreciated.
    • Berco
      By Berco
      I have an oil leak on my Kohler CH22 in my Toro 522XI (see video). I put in new head gaskets to remedy low compression. Then upon first start i had a large oil leak. It seemed to come from the aft oil seal. So i pulled the engine again and replace the seals. I re-installed the engine again today and the leak is still there. This is the leak now: https://youtu.be/pi382fXVXPQ What could cause it? I did blow out the air line from the fuel pump with compressed air into the crank case to clan out any debris. Could that have caused a leak this bad on the oil pan gasket? or another location? thank you all in advance!
    • katanski
      By katanski
      Can someone tell me how long is the drive belt from the engine to the mower deck is? 522xi with a 52" side discharge mower deck.
    • Berco
      By Berco
      I have a transaxle from a 518XI that i have as a spare. I would like to put some caps on the two open hydraulic lines, but i am having some hard time figuring out the thread and type to mate with the existing tubing. Does anyone know the specs for can point me to a fitting that will work? thanks!
