Rob R
GT 14 Three Point Hitch Fabrication
Pollack Pete
Nice job......VERY nice job.Nice GT-14.Love them.I have four or five myself.Whatcha gonna use the 3 point for??
Ed Kennell
Now that's some serious hitch.   :scared-eek:
Rob R
Thanks for the positive comments would like to make a scrapper three point (out of an old air tank) and a also a three point platform for multiple around the house use....
Rob R
Oops re-read my initial post need to correct the price of the 20" drawbar from Tractor supply the cost was $39.00 NOT $139.00.....
KC9KAS
Glad you cleared that up, because I bought a cat "0" for about $20 from Rural King!
Very nice fab job on your 3 pt lift...Nice GT-14 also!
meadowfield
Nice work, made one myself. Have you Plans to fit check chains?
Edited by meadowfield
Rob R
No plans for check chains, don't think they are needed as I made collars for the uplift bars which prevent the horizontal bars or draw bar from hitting the wheels etc.
Trouty56
Very nice job....
woodchuckfarmer
Nice fab , looks like on of the big boys from the rear
Rob R
Yes sir I was also surprised that a class (1) hitch fits like a glove with a little bit of welding and TLC.
Rob R
Okay so we finally got some decent weather and I had a chance to put all the pieces together to complete my GT 14 3 PT hitch and platform (good for 400 lbs plus). Hope you like it tried it out today with my wife on the platform and it work flawlessly.....
post-12028-0-95676000-1426174279_thumb.j
post-12028-0-68540000-1426174289_thumb.j
post-12028-0-13608200-1426174297_thumb.j
post-12028-0-16488600-1426174308_thumb.j
post-12028-0-49455900-1426174317_thumb.j
  • Like 7
js5020
Nice work on the hitch.  Nice machine also, I wouldn't mind having one to keep the 16 Auto company in the shed.
Edited by js5020
Rob R
Yes what I like about the GT 14 is the weight and might of a relatively small package, the front cast iron grille is very heavy that plus the heavy duty frame and the cast iron Kohler 14 HP engine makes something like the back pallet I built work. My guess so far is that the pallet will support and lift about five hundred pounds before it starts lifting the front end of the tractor.... this is the max I want to support on my home made back loader.... so I will use this a my fall safe to protect the tractor hydraulics, the back loader and my overall safety!
AMC RULES
Neat build.   :handgestures-thumbsup:
GT14
:woohoo:  Very nice
Digger 66
At the risk of sounding too critical of an otherwise pretty cool project but , would it not have been beneficial to bend the ends of the top link arms in at the top 10 degrees for smother movement & less wear on the pins ?
post-12028-0-92729300-1422042660_thumb_z
Rob R
Technically yes practically no, I and the next owner will be in our grave before any significant wear occurs on these heavy duty arms, plus it keeps just enough tension so that the horizontal arms center and do not hit the tires (so I don't have to add any additional chains.  Thanks for the comment
RedRanger
capacity 400# plus......checked it today with wife on platform.....worked flawlessly.  lol
I hope she's not reading this thread.   :laughing-rofl:
Rob R
10-4 on the last comment.....  I used her to chk the operation would take both of us to get to the 400 lb test. :bow-blue:
neil
Awesome job,
Would love a rig like that for my GT14
papaglide
I wish that I had my GT 14 again.....nice 3 point!
Brrly1
Don't forget your fall safety harness!! The three point looks good!!! Favorite tractor around here!!!
  • Similar Content
    • tractorboy79
      By tractorboy79
      I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
      Images below of cylinders to show similaritys.
    • wh315-8
      By wh315-8
      I have a question about the 69’ model. I took my tank out to work on carb easier. A couple weeks later as I put it back together & after cleaning everything; I replaced the white weatherstripping that was at bottom of tank and on the corners of the strap. Seems to be all that holds it in place. Because the strap around the tank will not go around the metal bracket on bottom and fit the tank. And even if it did the strap would only line up with the bracket mounting bolts which would be in the way. What did I miss? Didn’t pay close enough attention when I took it apart and can’t see in the parts diagram where the strap does go around the bracket. The weather stripping is tacky enough that the tank stays in place and it is a made to fit perfectly in position. Just seems that the metal strap is pointless.
    • tractorboy79
      By tractorboy79
      I have a old gt14 and the plastic plates or control panels are way past their prime, and I saw someone was remarking them with a 3d printer a little while back and I was looking to se if I could find the file but no luck. If anybody has info that would be amazing. Thanks for your time and anything helps.
    • Zeek
      By Zeek
      I decided I needed a way to carry some things around when working with the tractor. This is not a "Wheel Horse" attachment, but will work with any Category 1 three point. The idea came from a Kubota guy that did some great videos on how to make it.
      I decided to go with a Rural King "King Kutter" frame for three reasons: 1) it was red and I didn't have to repaint it to match, 2) I liked the RK mounting points better than TSC because they were mounted away from the frame farther and accept quick hitch if you use that, and 3) out of three TSC location around me, NONE had thier County Line carrier in stock. RK had three for the same price of $159.
      I added a hitch receiver to move utility trailers. I beefed it like the video by adding a piece of steel and routing out the underside so it sat flush. For chainsaw carrier I routed out a 2x6 enough to fit the saw bar.
      My rear tires are water filled, but this adds a little more weight as well. I plan to get a big HF (1K) furniture dolly to put under it when not attached because it's too heavy to slide around. I can get that for $12. A handmade one cost more than that in just wheels.
      Here are some pictures of the build if you could use something like this.
    • Rob R
      By Rob R
      I am currently doing a ring, piston, hone rebuild on a K 321 off a Ford LGT 145 Tractor  on this machine they actually welded the rails to the bottom pan (see pics). My intention here is to put this puppy in a red machine (312-8 or GT14). I definitely have the small pan with the expanded bottom for the long dipper.
      Here's my questions:
      > Can I carefully remove the rails from the pan, cutoff the old front axle mounting bracket(s) and then drill holes in  the flanges to mount  to the Wheel Horse rails.
      > Since the engine is side mounted will the expanded bottom fit between the standard Wheel Horse rails?
      > If not possible to make this old pan work what flat pan would work and do I need to get the expanded bottom one (big dipper}
      > any recommendations here would be appreciated don't want to go down to many blind holes here...….
      Thanks much!
