Similar Content
By tractorboy79
By wh315-8
I have a question about the 69’ model. I took my tank out to work on carb easier. A couple weeks later as I put it back together & after cleaning everything; I replaced the white weatherstripping that was at bottom of tank and on the corners of the strap. Seems to be all that holds it in place. Because the strap around the tank will not go around the metal bracket on bottom and fit the tank. And even if it did the strap would only line up with the bracket mounting bolts which would be in the way. What did I miss? Didn’t pay close enough attention when I took it apart and can’t see in the parts diagram where the strap does go around the bracket. The weather stripping is tacky enough that the tank stays in place and it is a made to fit perfectly in position. Just seems that the metal strap is pointless.
By tractorboy79
I have a old gt14 and the plastic plates or control panels are way past their prime, and I saw someone was remarking them with a 3d printer a little while back and I was looking to se if I could find the file but no luck. If anybody has info that would be amazing. Thanks for your time and anything helps.
By Zeek
I decided I needed a way to carry some things around when working with the tractor. This is not a "Wheel Horse" attachment, but will work with any Category 1 three point. The idea came from a Kubota guy that did some great videos on how to make it.
I decided to go with a Rural King "King Kutter" frame for three reasons: 1) it was red and I didn't have to repaint it to match, 2) I liked the RK mounting points better than TSC because they were mounted away from the frame farther and accept quick hitch if you use that, and 3) out of three TSC location around me, NONE had thier County Line carrier in stock. RK had three for the same price of $159.
I added a hitch receiver to move utility trailers. I beefed it like the video by adding a piece of steel and routing out the underside so it sat flush. For chainsaw carrier I routed out a 2x6 enough to fit the saw bar.
My rear tires are water filled, but this adds a little more weight as well. I plan to get a big HF (1K) furniture dolly to put under it when not attached because it's too heavy to slide around. I can get that for $12. A handmade one cost more than that in just wheels.
Here are some pictures of the build if you could use something like this.
By Rob R
I am currently doing a ring, piston, hone rebuild on a K 321 off a Ford LGT 145 Tractor on this machine they actually welded the rails to the bottom pan (see pics). My intention here is to put this puppy in a red machine (312-8 or GT14). I definitely have the small pan with the expanded bottom for the long dipper.
Here's my questions:
> Can I carefully remove the rails from the pan, cutoff the old front axle mounting bracket(s) and then drill holes in the flanges to mount to the Wheel Horse rails.
> Since the engine is side mounted will the expanded bottom fit between the standard Wheel Horse rails?
> If not possible to make this old pan work what flat pan would work and do I need to get the expanded bottom one (big dipper}
> any recommendations here would be appreciated don't want to go down to many blind holes here...….
Thanks much!
