craigbic
Question about removing snow blower from 314-8
brianc423
I have to say, I don't know if anyone else has other non WH equipment and tried putting a plow or blower on a JD for any other brand, they are not necessarily easy or quick compared to a WH. Plus, attachments and parts for say an older JD are not nearly as easy to find. When I installed the flag for my blower I just got on my '86 310-8, I didnt seem to have trouble, just used a key style cotter pin.
-Brian
brianc423
Oh and out of curiosity, do you guys have keep the lift assist spring attached too with the flag if you leave it on?
craigbic
Since I originally posted the question and what with all the snow Massachusetts has been dumped with the last month, I have become an "old pro" at swapping back and forth between the plow and snow blower - being able to do it in under 10 minutes. During the first  3 or 4 swaps I did, I wondered if I should leave the lift assist spring on the flag. When you look at it dangling there with the plow attached, it looks like it might interfere with the raising and lowering of the plow. Despite that, on the next swap, I tried leaving the spring attached and everything seemed hunky-dory for an hour or two until "something" knocked out one of the clip pins to the plow frame lift linkage which is right where the flag and lift spring are. The plow dropped to the ground and stayed there. Perhaps the clip pin just finally broke but I wasn't taking a chance so I immediately replaced the clip pin and then removed the blower's lift assist sprint. I left the flag attached. Since then, I've done several more swaps and I haven't had any problems.
varosd
On the 520's (at least 88/89)  I just have to remove a dash plate held on by 4 screws and its right below!
one bad shoulder and now the left one is messed up. I'm all hydro lift with the 520 with thrower and 416-H with the blade.
Forest Road
Well done Craig! Apparently it's your fault that Boston has received record snowfall. Shall we assume you're happy with your purchase?
craigbic
Yes! Extremely happy with my purchase!
Another update: I tried leaving the spring on again, but this time with the plow's pin clip on the opposite side so it couldn't get knocked out by the spring (if that's what really happened) after which I plowed through several storms without the clip falling out. That said, when I tried to swap back to the snow blower, I found that the spring still being on didn't allow the snow blower to push up high enough into the front bracket to lock into place. Had to go underneath with a wrench and back off the spring tension to get the blower on and then retension the spring. So it didn't save any work.
brianc423
I have decided to leave the spring attached to the tractor...but I take the flag off. Since its just a quick clip for me. What takes longer is the damn belt. Haha.
  • Similar Content
    • jledonne
      By jledonne
      1966 Lawn Ranger PROJECT
      L-106 Lawn Ranger with non-running Tecumseh H60, 6hp.  Engine lost compression, reads 25 PSI.  No visible external damage to block or cyl. head.
      Mostly original, one owner tractor w/ 32” mower deck and 32” snow blower (STR-3240) both serviceable.
      Very good sheet metal.  Original seat has tears.  Newer carburetor, original included.  New recoil starter (uninstalled).  Replacement front wheels/tires.  Originals included, one has broken hub.  Original rear WH tires.  Two sets of tire chains, one new w/ tensioners.  Box of small parts and original documents.
      Good candidate for restoration or repower conversion.  $275 OBO.  60+ high-res. photos online, PM or call/text 610-248-6471 for link.  Located in PA, 18072.
    • sraces
      By sraces
      I purchased my 314-8 new in February of 1996.  It's been a great tractor.  But a few years ago I had landscaping done and contracted for lawn service.  So the tractor has been sitting in the garage for a few years.  Bought a new battery.  It cranks hard, but won't fire.  Probably needs the fuel lines or carburetor cleaned.  It also needs the clutch shock replaced.  I have the new shock and belt.  Just haven't gotten around to replacing them.  Deck is in excellent shape with new spindles before I parked it.  Comes with the nice pull behind spreader that has only been used twice.
      Thanks for you consideration.
    • Donavon
      By Donavon
      Need ideas to convert my 1054 A Frame plow into a snow blower
      Any idea's?
    • PWL216
      By PWL216
      Selling a two stage snow thrower in very good condition. Works great. Comes with small box of new in-package parts. Can deliver to Zagray.
    • Spottedeventer
      By Spottedeventer
      Hi! The shafts of my fathers old 314-8, deck number 73449 have worn to the point the blades don’t stay secured. I’ve struck out tonight trying to find a part number. If anyone can assist, I would greatly appreciate it.
      thank you,
      Patricia
