Question about removing snow blower from 314-8
By
craigbic, in Implements and Attachments
Similar Content
By jledonne
1966 Lawn Ranger PROJECT
L-106 Lawn Ranger with non-running Tecumseh H60, 6hp. Engine lost compression, reads 25 PSI. No visible external damage to block or cyl. head.
Mostly original, one owner tractor w/ 32” mower deck and 32” snow blower (STR-3240) both serviceable.
Very good sheet metal. Original seat has tears. Newer carburetor, original included. New recoil starter (uninstalled). Replacement front wheels/tires. Originals included, one has broken hub. Original rear WH tires. Two sets of tire chains, one new w/ tensioners. Box of small parts and original documents.
Good candidate for restoration or repower conversion. $275 OBO. 60+ high-res. photos online, PM or call/text 610-248-6471 for link. Located in PA, 18072.
By sraces
I purchased my 314-8 new in February of 1996. It's been a great tractor. But a few years ago I had landscaping done and contracted for lawn service. So the tractor has been sitting in the garage for a few years. Bought a new battery. It cranks hard, but won't fire. Probably needs the fuel lines or carburetor cleaned. It also needs the clutch shock replaced. I have the new shock and belt. Just haven't gotten around to replacing them. Deck is in excellent shape with new spindles before I parked it. Comes with the nice pull behind spreader that has only been used twice.
Thanks for you consideration.
By Donavon
Need ideas to convert my 1054 A Frame plow into a snow blower
Any idea's?
By PWL216
Selling a two stage snow thrower in very good condition. Works great. Comes with small box of new in-package parts. Can deliver to Zagray.
By Spottedeventer
Hi! The shafts of my fathers old 314-8, deck number 73449 have worn to the point the blades don’t stay secured. I’ve struck out tonight trying to find a part number. If anyone can assist, I would greatly appreciate it.
thank you,
Patricia
