zanepetty
753 axle end play
zanepetty
i had to take my wheel off my 753 today. I know each axle has the regular small amount of end play but when you put the hub on, do you pull the axle all the way out then tighten the hub so there is no play or push the axle all the way in and tighten so there will be end play? Please help. Thank in advance 😀
bmsgaffer
The axle end should be flush with the hub so that the key sits in the right place for the set screw. :handgestures-thumbupright:
stevasaurus
Welcome back Zane...been a while.  :)  Brandon is correct, axle end flush with outside of hub.  :happy-jumpeveryone:
zanepetty
Thanks guys!! I've mised being around! I've been riding my tractor around all morning by the way!!! Just had to make a pit stop to change the brake shaft sealðŸ‘
