km3h
MULE DRIVE BEARINGS
km3h
I have two mule drives with tight turning bearings in the pulleys. They turn easy enough but will not spin freely. The parts diagram shows no replacement for these bearings. Are they replaceable using a standard bearing or must I buy new pulleys?
skrusins
If you have a needle for your grease gun you can try  that first. Their are no replacement bearings.
gwest_ca
If the two pulley halves are riveted together there is a good chance you can replace the bearings. They make a 6203-2RS with a 3/4" ID if you get that lucky.
Garry
  • Excellent 1
can whlvr
if its an older mule drive you can repace the bearings,my older mules are cast pullies,the newer style with pressed pullies are not,the bearing is installed permantly installed
km3h
I was afraid that would be the case. Looks like I will b e buying new pulleys. I may try soaking them in a mixture of kerosene and transmission fluid. They turn with no noise or rough spots. The outside pulley spins but the inside just turns. It is not tight but does not spin like I think it should.
groundhog47
I pressed out the old bearings, the flange was just unrolled, put new bearings from mower spindle stash, and worked the roll back down over bearing. Tried on a smaller bearing pulley (mower idler) and rolled lip split (determined the outer race is a must to get a push on) and bearing came apart leaving race in pulley, experiment failed there. Mule pulley seems to be working fine though. Just need about four or five more to fix up for spare mules and refine process.
gwest_ca
These Stens pulleys are spot welded together and you can drill out the welds and replace with machine screws and Nylock nuts. Any I have seen the welds are evenly spaced so balance should stay very close. I made a jig for the drill press to keep the new holes equal distant from the center.
Flat idler
https://www.bantasaw.com/catalog/viewproduct.asp?i=&p=4031
V idler
https://www.bantasaw.com/catalog/viewproduct.asp?i=&p=4657
This dealer is in Ontario Canada
I keep many spare bearings so as I get this style of pulley I'm never stuck the next time. Also have flanged metric bushings so the 6203 bearings will also work for the 3/8" and 1/2" mounting studs. That's what i do for the 7451 clutch idler using this pulley
https://www.bantasaw.com/catalog/viewproduct.asp?i=&p=642
Garry
km3h
Thanks Gary and everyone. Seems like there are some choices. With all the work that mule drive is asked to do, I would have thought the bearings would have been easily replaceable.
can whlvr
the pullies are not really expensive,for the guys that arnt willing to tear them apart,some of the pullies are getting thin by the time the bearing wears,so take a good look at the pulley before doing too much too them
Mr. 856
For what its worth on my blower the pulley shaft bearings cups were riveted together. Upon opening the cups after drilling out the rivets I was surprised to see the cups were the actual bearings. I was able to remove all the balls and clean and degrease everything. After putting them back together and packing with grease they roll like new ones. These aren't like the sealed bearings we are used to. The cups have groves that hold all the balls.
Kelly
The pressed steel pulleys are throw aways, yes you can soak them or try to grease them, but if you are doing it after you hear they are bad, it's only a short term bandaid.
   In the early 70's to mid 70's they used cast iron pulleys with removable bearings, I think cost stopped that, new pressed steel pulleys are about $20-25 each I've seen them cheaper at times, I sell the cast iron pulleys when I have them in stock, for $50 a pair most need bearings, but after you have a set you only need to buy bearing ever again, @ about $12 a set depending on your supplier
peter lena
on those 6203 ( 3/4 ) bearings , the most important thing is the lubricant, typically those pulleys get quite hot and cause lubricant failure . easy to pry off the seal , clean out the bearing and refill with  LUCAS RED N TACKY GREASE,  its 550 drop point will stand up to high heat and heavy use, since changing over a number of bearings to that grease , no noise and no failures , just my input on what was  a common failure , pete
Lee1977
The bearings can be replaced on the spot welded ones too. The flat idler is the easest as it is not welded in the center like the vee idler. The first thing take a small bit and drill a reference hole between the spot welds.  Then drill out the spot welds. The hole won't be perfectly spaced, that is the reason for the reference hole. Vee idlers can be a real pain to get apart, but I've done a couple. Here is a set that I did,
Jerry Hugo
Thanks Lee1977, this was one of the best posts that I have seen - I knew it was doable, just had to see that someone tried it and got it done.  I'm going to do it today - I have 8 520's so it will be worth it, not having to purchase the Stens replacements.  Just replaced an idler pulley on the main drive belt yesterday - not as bad as I had thought it would be.  Took about 3 hours in total but did a lot of cleaning up in the process and changed the Hydro filter as long as I had the fender off.  Thanks for your post.
squonk
Lowell has those pulleys for $20. Your labor isn't worth the 20? :confusion-confused:
Jeff-C175
42 minutes ago, Jerry Hugo said:
knew it was doable
There's a post by @PbFlinger on doing the same with the pulleys on his 37" deck.  More pics that illustrate the process.
Edited by Jeff-C175
peter lena
@km3h great opportunity to replace those 6203- 3/4" ID bearings , but most important is the chance to use some LUCAS EXTRA HEAVY DUTY , POLYUREA , HI TEMP , ANTI SLING GREASE IN THEM ,  done this easy swap , on my deck spindles and my 3 mule drive bearings. recently bought 2 new pto pulleys , first thing i did was easily pop off the wide bearing side seals , with pocket screw driver . carefully wiped out original (  generic grease  ) that will fail . repacked with same amount of  lucas hi temp grease . at 5$ a tube at wall mart , its the bearing saving deal. this is not complicated , its simple and easy. this bearing grease will stand up to hi temp and extreme stress , why not change to it?  my decks are quiet and very smooth , no hi pitched bearing whine , this is my own experience , do what you like , keep it greasy , pete
Wheelhorse#1
Thanks for the information guys .Very helpful as always.
Mr.Lena
I know you are a big fan of the Lucas Extra heavy duty,Polyurea ,high temp ,anti sling grease.
I have used it and it is good stuff !!
However I came across a stock of this Pyroplex Blue NLGl #2  Thoughts ?
peter lena
@Wheelhorse#1 thanks for the shout , looks like its in the class , could not find an exact equal to lucas . but it is definitely better than average . that heavy equipment rating , is beyond average . worth a try.  those small bearings spinning at hi angular load , is what heats up and causes lubrication failure . on my first mule bearing failure , you could not touch the bearing , now my bearings , don't give me any problems at all . always looking for reliable operation , experiment , thats what i do , greasy pete
Wheelhorse#1
Great Pete
Thanks for your opinion on this grease,I thought it looked pretty good.Plus it’s blue!😉
As you know proper Maint is number one in keeping these bearings going for a long life.
  • Excellent 1
squonk
Bearing #'s
V pulley 6203-12 2RS C3 3/4
Flat 1630-2RLD-C3
  • Excellent 1
  • Similar Content
    • 87 312-8
      By 87 312-8
      looking for mule drive bearings for a 36 inch rear discharge deck 1986/87 312-8, thank you
    • Joel
      By Joel
      My dad gave me his c105 with a plow attachment. I have taken the mule gear off to replace the belt, check bearings, and replace fasteners. Although now I cant seem to get the darn thing back on. I know I should've taken pictures b4 tearing into it. I guess I got too excited. If someone could send a pic of how theirs is mounted thatd be great!
    • Rock farmer
      By Rock farmer
      Are the bearings replaceble  by themselves?
      or do I need to replace the pulley?
       The inner vee pulley has a destroyed bearing.
      can I use a puller to remove the outer idler pulley?
      or will I destroy that one trying to get it off?
      they seem to be pressed on.
      are replacements available?
      thanks!
      joe
      I'm talking about a 1990 312-8 with a 42” deck.
    • Danny856
      By Danny856
      Hey guys, I'm sure the answer is somewhere on this site but for the life of me I can't find it. I have an '89 Wheel Horse 310-8 (210K806) and my mowing deck is 0542MR04. I need the belt that connects the two. The one that goes from the engine/mule drive (?) down to the deck. It kept poppin off. I thought I finally had it set right but then it came off again and I ran over it. Can anyone help? Thanks in advance. Dan.
    • IthacaJeff
      By IthacaJeff
      Hi folks,
      Before I go about destroying things, how is the pulley on my mule drive removed. The bearings fried the other day on the outer pulley. There are no snap rings, so I assume it is a press fit. But before I pull out the wheel puller, is there any trick to this?
      Thanks, all.
