IvanW
New Memeber! My First Wheel Horse! Pics
IvanW
A couple weeks ago, I picked up this D180 and snow blade for $200. It doesn't run because it needs rewired and the air breather put on. The seller still has the air breather which he'll send to me as soon as he finds it. The tractor has hydraulics, drawbar and brand new Carlisle Ag tires on the rear. I would like to get it running but will need some help. First, does anyone have a wiring diagram for a D180? Where can I find a manual for this? Also, where would be a place to get parts for this? The tractor is entirely intact (minus the air breather) except for a couple sheet metal panels which I'd like to put on.
Thanks in advance!
-IvanW
post-14444-0-62598600-1419702480_thumb.jpost-14444-0-16455800-1419702583_thumb.jpost-14444-0-90788600-1419702691_thumb.j
  • Like 8
Ed Kennell
Can't beat that deal....a $200 plow with a free D 180 w/ new ags.
Get your model and serial numbers off the tractor,
Go to the manuals section and search for your tractor and download your manual.
When you need parts' put an ad in the wanted section of the classified.
Oh , :WRS:
Tankman
Never owned a D series Horse but, for the price I too would have one. 'Specially in the condition of your new Stallion!
Welcome to the forums, here you'll find plenty of help for sure.
Check the manuals section and you are sure to find some *.pdf literature to get you back in the saddle again.
Have fun and be sure to update the forums!   :woohoo:
"D"- Man
Ivan, you definitely scored a good deal, the wiring  diagram should be in the manuals section on this forum. Did you get the console panel with the I.D. / Serial # tag?   The inlet barb on the side of the carburetor has no fuel filter hose going to it.  The pump control rod is disconnected from  forward/neutral/reverse lever.  Will you be replacing the alligator clip on the coil?  If you need the tins for the engine I have a used set, Mark.
Edited by 23 Automatic LSE
Retired Wrencher
:USA:  :wh:  and  :WRS:  Ivan looks nice a reel worker. also WOW 14444 PEOPLE BELONG TO THIS SITE NOW.    That is amazing.
AMC RULES
  Good deal, nice  :wh:
:WRS:
gregg'shorses
I hope he didn't run it very long without the air filter.
953 nut
:WRS:    You done Gooooood! The rear tires alone cost twice what you paid. As you go through this adventure you will find lots of help on here.   :text-welcomeconfetti:
Digger 66
Greetings .
What other plans do you have for your tractor ?
KC9KAS
:WRS:
As stated above, check our manuals section, then start a new thread for questions.
Geno
Very nice score Ivan!   :handgestures-thumbsup:   Glad you found us and :WRS:
JERSEYHAWG /  Glenn
Wellcome to red square, for that price you should be called jesse james, bargin ,, bargin.
Glenn
IvanW
Thanks for the welcome everyone! :thanks:  As one member pointed out from the pics, the ID plate seems to be missing. Would there be anywhere else on the tractor with the serial #?
-Ivan
toolmaker40
Welcome , good luck with your project
brandonozz
Welcome to :rs:
Great find and even better price!
fabricator2009
You did very well. Nice looking tractor.
GT14
Super score, I have been looking for one of those myself.
:text-welcomewave:
gwest_ca
-Ivan
Only on the ID plate. Post all the numbers of the engine including the serial number and possibly it can be identified using them.
There were only 3 models using the 18hp engine but just 2 model D-180's. The first was named a 1973 18hp Auto.
1974 model 1-0611
1975 model 1-0612
A search of the Manuals using these numbers will get you some info.
A good later service manual also applies to the earlier models
Garry
Ed Kennell
        :text-yeahthat:
   There you go Ivan.....I knew our manuals GURU from the North would help.  Thanks Garry.
pacer
The ID plate would be on another part you are missing - that open spot under the steering wheel should have a cover there and the tag would be riveted to it. If the PO is searching for the air cleaner ask him to also look for it, and also the tin/covers for the engine (those are MUST have parts)
You done good on getting that thing, they are beasts! I love mine....
Live4outdoors
Welcome, got a great deal there, it looks good, now for the fun part, the working on it, wish I could help but don't have any of those series tractors
JackC
In 1973 they were 18 Automatics.  Starting in 1974 they were re labeled D-180s.  Since it is a D-180, the seat suggests it could be a 1974 or 1975 model year. I believe a different seat was used starting in 1976.  They are beasts.
km3h
Another Home Run. What a deal. That is one good looking tractor and you have come to the right place for help.
JC 1965
Great deal Ivan.    :WRS:
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
    • Brandon Byers
      By Brandon Byers
      I know I'm half a year ahead of schedule!
      I picked this 1974 D-180 up early last year. It had a pretty hard life, and the previous owner gave his best attempt at keeping it alive. Hydro was strong so I serviced it and put it to work mowing all year. I decided if it would make it through the season then it would get some TLC. By fall it was burning about a quart of oil an hour but it made it. I have no clue how many hours are on it, every hole, bushing, bearing on this tractor is pooched. If you look closely, somebody used two 1" NPT Pipe Flanges to rebuild the mounting points for the upper 3 point cylinder. Hey it works!
      I rebuilt the steering gearbox and re-bushed the front axle along with making new spindles.
      I had the 482 Kohler bored .20 over (it was .10 over already) and gave it a rebuild with the intention of putting it back to work on snow duty.
      I then dawned on me that this tractor will be 50 years old next year - and these old D's are becoming harder and harder to find anymore. So I decided to customize it a bit and go for what a maybe a dealership would offer for a 50th anniversary model if Wheel Horse was still in business today (In another universe, maybe!)
      As D's aren't known for their looks - and I can't leave anything alone. I took approximately 2 Inches out of the grille and bezel.
      I updated most of the wiring and lights. Gave it a new set of Carlisle Ags along with Vredestein front ribs. It got a new seat and I painted all the accents aluminum.
      I patched, rebuilt the 48" deck and put new blades, wheels, and hardware on it. The Blade & 3 point scoop somebody adapted to it also got some attention.
      Lastly I stripped it most of the way down and painted it with IH red acrylic urethane enamel.
      I always forget to take pictures during my projects but here's a few:
      Before:
      After:
      Thanks for reading!!
    • Crazy Old Red Horse
      By Crazy Old Red Horse
      Barn find 1975 D180. 608 original hours. Tractor and 48” belly mower look to be still in their original paint. Rear 60” finish mower looks like it has had one coat of new paint added at some point. Open to trades. Please email me with any questions or for additional photos. 35 miles north of Pittsbugh.
