saguaro
Tecumseh crank shaft end play
saguaro
Been going through the manual I bought for this engine and nowhere does it show how to get it within tolerance. :banghead:
So I could sure use some advice.
saguaro
The book says .005 to .027 for this engine. Right now I'm guessing it's over 1/16th. :banghead:
saguaro
Would a shim between the ball bearing and the engine cover fix it?
saguaro
Went and talked to some Toro mec's today. They said don't worry about it. Said I could shim it but that may just add metal to the oil and could end up putting something in a bind.
I'll call it a lesson learned for the next engine.
Something else I learned. Buy no disassembled engine unless you know it well or are willing to put someone else's puzzle back together. I found out mine consists of several puzzles. :banghead:
Michael Bullington
all my H-60 havea little endplay in them..I think it supposed to be that way ,,, I not a mechanic but it seems okay...Im curious what did you find inside?
saguaro
I did'nt open it up so no new news.
