Red Dave
Separate Lifts 414-8
Red Dave
Has anyone modified the lift on a 414-8 to lift and lower the front blade separately from the rear? Would like to use a front snow blade with a scraper blade on the rear slot hitch with independent controls.
wallfish
Haven't done this but my first thoughts are to make a way to "pin" or "latch" them to stay in the raised position.
Using chain for the front blade vs a solid link and the normal connection with a cable to the rear lift. Modify a way to easily pin or latch them separately in the raised position and this will allow independent use of each one using the one lift lever plus not too many modifications to the tractor.
$0.02
bmsgaffer
You could fab up heavy duty mounts and use a linear actuator (electric lift) for the rear...
can whlvr
heres a pic of a simple lift for the rear,it slides into the 2inch receiver
wh500special
WH actually employed john's idea on the GT-14. They offered little hangers that would hold the mower deck or snow blade in the lifted position while the rear hitch was free to cycle. And, likewise, there was another set for the rear hitch to hold it up while the deck or blade was in use.
Simultaneous multiple implement mounting really wasn't a wh hallmark on tractors not equipped with three point hitches.
A couple short pieces of chain with shackles to hold the unused implement up would be the easiest path.
Deere, Sears, and probably others offered rear hitches with their own integrated manual lifts. I don't know how extensive it would be to do, but you might be able to adapt one of their units to the rear of your tractor to obtain an independent sleeve or integral hitch.
Steve
shallowwatersailor
I put a Johnny Bucket Uni Sleeve Hitch on my 523Dxi this fall so that I can use a plow or snowthrower on the front and a scrape/drag plow on the rear. The 5xi uses a chassis that can mount the JB Uni Sleeve because the rails go all the way to the rear. It will not work on a traditional Wheel Horse.
Red Dave
Thanks for all your replies. I am going to look into the electric linear actuators Northern has a good selection. The rear of the 414-8 under the fender pan has room to fit one in there over the transmission. when I rebuilt the engine I replaced the three amp/ac stator with a 15 amp stator added a regulator and rewired the tractor, added 65 watt headlights and led taillights so it should have enough power for the actuator.
Edited by Red Dave
  • Similar Content
    • WH1618speed
      By WH1618speed
      1965 Wheel Horse 855 with 42" blade and chains
      Runs good
      Sheet metal is very straight, great candidate for restoration.
      Missing Belt guard
      Will sell tractor by itself for $500 without blade and chains
      Blade is straight and lots of cutting edge left... just a little rusty.
      Text, call, or email with any questions. If you call and I don't answer please leave a voicemail with your name and number. Thanks!
      I can also deliver to the big show in Arendtsville, PA... IF you prepay.
      Facebook Marketplace link with more pics: https://www.facebook.com/marketplace/item/598023068755689?rid=229092436403311&ad_id&rt=1&refID=0&refType=0&referral_code=commerce_attachment
    • Willhaven
      By Willhaven
      I bought my very first lawn tractor yesterday. It’s a 211-5SB. After mowing an incline yesterday (I went sideways) the blades stopped engaging. It took about 6-7 tried to get the engine to turn over this morning, and the deck still isn’t engaged. Any tips to debug for a novice? Pic of scalped incline and my tractor for reference. Thank you.
    • Anvil
      By Anvil
      I would like to check with you guys about the pros and cons of increasing the speed of the deck blades, possibly by increasing the diameter of the drive pulley on the PTO clutch. Anybody do this????? I'm not so worried about the spindle shafts on the deck as I grease the heck out of them on a regular basis. The Mule longevity however, without a grease fitting concerns me. Your thoughts????
    • MS GENERAL REPAIR
      By MS GENERAL REPAIR
      Does anyone have a illustrated parts list, or a link to one, for a 1984 Wheel Horse 48" mower deck that includes the spindle & blade assemblies?
      Thanks in advance for any help........................Mike
    • slpalmer
      By slpalmer
      Greetings all,
      Here is my 1977 C-160 in mid-restoration.  She purrs like a kitten.  They don't sell blades for this deck anymore (as far as I could find) so I bought some close and had a machine shop drill the extra holes to make them fit.  I should see tomorrow how well that works out.
      https://goo.gl/photos/1sJsDsajAcSTK3Kk9
      I'm in SE TX, looking for garden plow and tiller attachments for this sweet girl.
      Hope you enjoy the pics!
      Stephen
