JoeM
653 Help
JoeM
I need some 653 ID help. Picked this up the other day and started looking at parts etc. There is no model tag just the 653 decal.
A couple of the things that need sorted out are; the rear hubs on the uni drive have 5 lugs. The part manuals show 3 lugs, the transmission seems to be original?? The engine mount appears to be for a Kohler. The original engine was missing.
I am going to just leave the 51 years of love as is and I am going to clean it up, and get it moving with a spare Kohler. I do need the specs of the engine pulley diameter etc. as well as the height above the frame to the center of the shaft as well as the distance from the front of the frame to the center of the shaft.
There a snow blade in the pictures, is it Wheel Horse?
Any help will be appreciated.
Joe
post-6026-0-46374600-1417298130_thumb.jp
gwest_ca
I ordered 3-bolt replacement hubs about 35-40 years ago and the replacements came like yours with 5 bolts so they have likely been replaced.
Garry
JoeM
That makes sense. I am sure that helped limit the parts inventory crossing over with others.
Live4outdoors
Hey that should be a Tecumseh motor mount hh60 I believe. You can put a Kohler in but have to change wiring you can get the manual on the site here. I'm not home for a couple days but can get any pictures of an all original 653 that you may need just let me know or pm me
JoeM
So far it looks like there has been some changes. I am going to check that wiring today, I know when I first looked at the wiring it appeared to be butchered. I am betting the original motor was Tecumseh and someone changed It out for a Kohler. I have a 8 HP Kohler complete and I am going to install it, If possible when you get back  how about sizing that motor pulley. Some pics of the steering wheel, park brake lever (its missing), and the hood attachment in the front will be helpful.
Thanks
stevasaurus
Nice project.  :)  I don't think that snow blade is from Wheel Horse...almost positive.
JoeM
Looked closer at wiring and blade today. Wiring is for a Kohler and found traces of green paint on the blade, maybe John Deere.
Live4outdoors
Hey you bet, it will probably be closer to the weekend when I'm home but will shoot you some pics.
Live4outdoors
The pulley is 2 1/2 round by 2 1/16 deep. The front hood mount is a knurled nut similar to the ones to hold to the gas tank just a little longer, there's a member here that sells a wonderful kit just search him or he's on eBay. Here are the pictures you requested...anything else just let me know!
post-14030-0-51543200-1417803047_thumb.j
post-14030-0-55074800-1417803057_thumb.j
post-14030-0-13335100-1417803068_thumb.j
Live4outdoors
I couldn't find the knurled nut man on here but his eBay name is haasman28 he doesn't have any listed now but, you contact on there he will let you know how to get him on here to get some does a great job!
JoeM
Thanks to everyone for all the information. I have been gathering parts and hope to pull it into the barn this weekend and start to get her running.
Lane Ranger
Gene Simpson is  haasman28 and he sells some great knurled head 1/4 inch nuts like the original  ones used on the Wheel Horse hoods!
  • Similar Content
    • formariz
      By formariz
      Added the first replica HL-5 today on the 653, the first of a couple of dozen in the works. They are not connected yet, working on a bracket for switch.
    • Loganthedoctor
      By Loganthedoctor
      So this is my first wheel horse and i love it. Swapped an old 8 horse on it and it runs great. But the paint was going and rust was starting so I decided to fix that so here are the pics
    • on1wheelr1
      By on1wheelr1
      Good morning.  New to the forum and thanks for all the information you have posted.  I live in Northwest Indiana and I was wondering the value of what appears to be an all original 653 in running working condition.  The only thing that is not working properly is the starter.  It was given to me not running and I cleaned the carb and it fired right up.  So I am contemplating selling or keeping it but curious what it is worth.  Thanks.
    • on1wheelr1
      By on1wheelr1
    • zanepetty
      By zanepetty
      Hey guys. I need help finding a steering gear and shaft for my 753. I need it stat! There are a few on eBay that look like they might work but when I ask the seller they don't know can anyone help?? Thanks,
      Zane
