Toolmanbill 32 #1 Posted November 29, 2014 Does anyone know if a 42sd from an xt series will fit a 314-8?model#230000105.anywhere to get a good 42 or 48 sd deck? Share this post Link to post Share on other sites
RJR49 129 #2 Posted November 29, 2014 You might ask Wheelhorsedoc if he has one. Other than that the usual sources (Ebay, Craiglist, and this forum. I can't help with the fit question Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,921 #3 Posted November 29, 2014 If you want a real good condition deck you can still get a new one from Toro. Garry Share this post Link to post Share on other sites
ericj 1,578 #4 Posted November 30, 2014 yes the xt deck will fit the classic tractors you have to replace the xt quick attach deck bar with 1 from a classic deck. that is the bar on the deck that goes up into the quick attach mount on the tractor. in fact if you buy a new deck from toro the deck will fit either the classic or the xt tractors not sure how toro does this 2 different bars or what. it is simple operation to change 2 bolts good luck. all and by the way i did do this once a couple of years ago eric j Share this post Link to post Share on other sites
Toolmanbill 32 #5 Posted November 30, 2014 Thanks for the info everyone! Share this post Link to post Share on other sites
Toolmanbill 32 #6 Posted November 29, 2015 Wound up getting a used deck.quite an experience.bought from Glenn Cockerham in Malvern Pa.Found him thru craigslist in Pa.he has quite a lot of parts and implements.probably going to weld the old deck also.THANKS for all your help with this. Share this post Link to post Share on other sites
mikekot3 92 #7 Posted November 29, 2015 Thanks everyone for the information. I did not know that an XT series deck could be adapted to a classic series track by swapping the attach a matic brackets. mike Share this post Link to post Share on other sites
