Hammerhead 817 #1 Posted November 29, 2014 I am trying to sell my 1971 Charger 12 hp with auto trans. The buyer came by to test drive it and noticed it picked up speed while he was mowing. He is buying it for his wife to mow with and said that may freak her out if it picks up speed on her. I drove it and it barely picked up speed when I drove it and only did it with the blades engaged. We rebuilt the drive handle mechanism earlier and thought we had it fixed. We replaced the plastic piece on the lever drive system and thought it was ok. Anybody have this problem and fixed it somehow? I need to sell the tractor and now he wants me to fix the problem before he takes it. Any help will be appreciated. Thanks in advance...Keith Share this post Link to post Share on other sites
Geno 1,929 #2 Posted November 29, 2014 The tension on the spring under the center console may not be tight enough allowing it to speed up. Share this post Link to post Share on other sites
Callen 64 #3 Posted November 29, 2014 What Geno said and check the bolt that locks the pivot shaft down on the side of the hoodstand. Also check to see if hoodstand is tight on the frame. Share this post Link to post Share on other sites
pfrederi 17,910 #4 Posted November 29, 2014 From Electro manual Share this post Link to post Share on other sites
Callen 64 #5 Posted November 30, 2014 Also, check your transmission mounting plate for cracks. Share this post Link to post Share on other sites
Hammerhead 817 #6 Posted November 30, 2014 Thanks a lot guys! I will try to adjust it today and hope it works. I am selling it for $700.00 and I could really use the money for bills! Share this post Link to post Share on other sites
KyBlue 655 #7 Posted November 30, 2014 Know that feeling... Hope it fixes it for you Share this post Link to post Share on other sites
RMCIII 838 #8 Posted December 4, 2014 Nothing really to worry about. Just probably excited knowing it is going to another good home! Rob Share this post Link to post Share on other sites
Nathanielperz 150 #9 Posted December 27, 2014 Also, check your transmission mounting plate for cracks. My 1276 had cracks in the mounting plate. The transmission was very low on transmission fluid when I brought it to my house.... The tailgate on the truck was down and it kind of rolled out of the back when my grandpa had to stop suddenly.... Pretty scary but at the same time hilarious! The trailer hitch took a pretty big chunk out of my driveway! Then it kind of bounced and rolled into the grass... Share this post Link to post Share on other sites
smoreau 658 #10 Posted December 27, 2014 From Electro manual I installed this in my 875! I replaced the plastic slide when restoringit and it woud always jump forward on me. The new slide didn't help and it did it on a trailer for me with me on it. NOT FUN! I had a 69 charger that I parted out to save 3 other tractors and that was left over. After instillation in the 875 (not original) it is SO MUCH SAFER!! It is now a pleasure to drive and the lever now stays were i put it! Had to make some very minor modifications to the tractor tunnel, but well worth the modification! 1 Share this post Link to post Share on other sites
