Similar Content
By sjoemie himself
Hi all.
This topic will be dedicated to the upgrades and modifications I'm going to do to my 512-D with sweeper attachment.
The plan was to complete my mini IH 1468 before starting to work on the Wheel Horse but since the leaves are coming down quick I developed an 'itch' to get working on the Wheel Horse.
First things first, I had to get it running again. New ignition switch and new inline fuse, aswell as cutting out all unnecessary (for now) stuff solved the non-running issue.
Dashboard wiring seems to be OK
This is a mess. Two unnecessary relais, one unnecessary switch and a bunch of unnecessary wires everywhere.
Next up will be a new battery and probably some modifications to the pto-clutch and new oil all around. Also I'm on the lookout for new filter elements for the oilbath filter for the Robin DY41D engine.
Done for now.
Major upgrades and or restoration will have to wait until after I finish the Murray to IH 1468 project.
Running again. Listen to that THUMP!
Almost forgot to mention.. probably needs some new rubber mounts
Greetings from the Netherlands, Mark
By Evguy
I recently purchased a GT1800 with a blown engine with the intent of conversion to electric.
This is my first Wheel Horse and I have never seen it running. I need a little work on it but it looks sound.
I will not be hacking it up, If this project goes poorly, I would want to bring it back to stock operation with new engine.
I will be creating a blog at some point to show conversation.
Budget will be tight, I will be using parts from past projects, but motor will be new permanent magnet DC.
Voltage will be 48v, as many old lithium batteries that I can fit in. I plan to retain pto clutch.
By sjoemie himself
As requested some pictures of my 1986 Wheel Horse 512-D with sweeper attachment.
By kurm
You can search for the specs but here are some links:
https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro&lang=us_en
https://lookup3.toro.com/partdex/modlinfo.cfm?xCaller=Toro&o=2&x=22004&b=9900001&e=9999999&m=73552&y=1999&n=523Dxi Garden Tractor&channel=CN
https://lookup3.toro.com/partdex/modlatch.cfm?xCaller=Toro&x=22004
This is a beast! Comes with the 60" deck and also a 48" deck and a new battery. New belt (installed but unused), newer hoses, regular maintenance.
There are wheel weights too but idk if they fit this unit as I've never tried.
758 hours
I got a zero turn and a Kubota tractor and this has sadly become ignored.
By classiccat
New member ...and another old-Iron guy here...with my 1st Wheel Horse tractor.
I was looking for something mainly for pulling an old aluminum boat (18' starcraft) around the property.
Capability to mow and haul yard waste would be a bonus.
2 weeks ago, a C85 showed-up on CL for a song.
He couldn't start it for me and it didn't take me long to figure out why...
This will be a running thread / rolling-restoration as I bring her back to her original, Black-Hood glory!
(DISCLAIMER: I'm an engine-wrencher ...I have the tendency to leave my foot off of the project's gas when the engine starts drinking it!)
