Marchettiman
523Dxi hydro problem
Marchettiman
Have recently bought a 523Dxi wheelhorse here in the UK, only 750 hours showing since new.
When cold the transmission only drives forward and reverse with low engine speed, the power steering doesn't work despite cycling the steering wheel through full lock nor does the hydro deck lift work. After 10 minutes or so the tractor will drive ok, power steering works intermittently and finally all works well after about 20 minutes of use. The last thing to come on line is the deck lift. It seems once the hydro unit is hot everything works well.
I have changed transmission oil for 10w30 synthetic oil, changed the hydro filter with a new Toro part and cleaned the power steering filter,  there are no obvious leaks.
Any ideas before I change the hydro pump unit?
boovuc
I don't own an Xi Series but I have seen threads on this topic over the years. You are not the first person to experience this anomaly with an Xi series tractor. This just may be how they act when cold though if others don't experience this with their tractors, there must be a reason it is doing it. I know I let my 520H spin for 5 minutes minimum in cold weather before moving it.
If you haven't done so, do a search on transmissions about it and see if you come up with one or two threads/topics on sluggish when cold hydros.
gwest_ca
Welcome to the forum.
In case you don't have it here is the service manual for the transmission
Garry
RMCIII
Marc - I have an "xi" and have expierenced a little of what yo udescribe.... Nothing to what you are saying though. It only does it when it is very cold... Mine is the lift is slow and forward movement seems to be "slower" than normal. So, as Boo pointed out, I just let it warm up and no issues.
Rob
shallowwatersailor
I have three 5xi including a 523Dxi which I purchased this past summer. Last winter I used the 518xi for snowplowing.  It does stay in a garage that cools when really cold to approximately 4 Degrees Celsius. It only gets used when it snows plus I live in an area that receives less snow compared to other parts of the country. This winter we are predicted to receive a maximum of 1.27 meters of snow for the season. The 523Dxi is doing the snow duty this winter so I don't have experience yet with extremely cold weather and its operation. Probably not related but I have noticed that there is more air movement due to the radiator fan than with the air-cooled Kohler.
I have a 200 watt magnetic heater to place on the transaxle case when cold. It does seem to help with the response when first starting out. At the end of plowing one time last season I felt the sump on the 518xi transaxle and it was warm, even though it was -8 degrees Celsius. I would suggest the heater and maybe one for the engine sump as well before considering tearing into the transmission.
  • Similar Content
    • cyrus
      By cyrus
      1996 416-H Wheel Horse Garden Tractor
      Model # 73423
      1355 hours
      Features Electric Clutch Hydrostatic Drive Hydro Lift (mid & rear) Accessories 48" 3 blade mower deck Model #78360 Newer Blades 48" single stage High Chute Snowblower Model #79360 Side Wings for 60" cut sidth Newer Chain and Drum Sprocket 20lb Rear Wheel Horse Wheel Weights Rear Wheel Skid Chains Soft Side Snow Cab Rough but useable. Other info New Battery New Hydro Lift Cyl Hoses New Main Electrical Wire Harness Recent service (Engine Oil, Hydro Oil, Filters, and Chassis lube) Tires are in good shape with no leaks A bit cold blooded, but starts and runs great once warmed up uses no oil.
      located in Zeeland Michigan, purchased new from Westenbrook Mower in late 95. My parents are moving to a townhouse and have no further need for their trusty horse. I have my own, so off to new pastures for this one.
      Pick up only.
      8509515355704655080.mp4
    • TonyI
      By TonyI
      I have a 418-c  worked great plowing over the winter.. but now is having no power pulling a load fwd.
      replaced the fluid.. the old fluid didn't look bad. feels a littls better., but still significant loss of power and high pitched whine coming out of the hydro.  the lift works fine
      is there a repair manual our there for the hydro?  Is there a way to reverse flush the system?   I hear sometimes the hoses crack internally and clog things up.
    • mattd860
      By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The kit operates very simply and similar to modern tractors. When the pedal is pushed forwards the tractor will move forwards. When the reverse pedal is pressed downwards, the tractor will moved in reverse. If the operator takes his foot of the pedal at any time, the pedal will automatically center itself and the hydrostatic transmission will return to neutral (stop). This enables the operator to use both hands on the steering wheel or one hand on the wheel and the other operating an attachment like a snow blower, plow, etc.
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      The pedal kit fits the following series tractors with Eaton hydrostatic transmissions: C-1X5, 300, 400, 500.
      My kit can be adapted to older hydrostatic tractors with the Sundstrand transmission, however, you will need to find an updated hydro cam commonly found on ebay. Message me for more information.
      Here is a link where you can download the installation manual: CLICK HERE
      I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      If anyone has any questions please feel free to PM me or post your question here and I will be glad to help. Or you can email me at mattdarling02@hotmail.com.
      Thanks!
      Below are pictures of the complete kit and the pedal installed on the tractor. Some modifications have been made since these pictures were taken. For example, the reverse pedal is now cast in aluminum instead of the steel pedal shown below.
    • bigcreek
      By bigcreek
      Price DROP!!! Horse traders out there, this great tractor is available at new price.
      99.5 hours, Horse runs like new. Really Like this horse to go to good home. Let’s talk can provide more images if needed
    • olivertractor
      By olivertractor
      I was pulling a roller and thatch rake the other day with my c120 hydro and noticed oil on the back of the fender. On looking closer I saw the plug thing on the back of the pump leaking oil. Any advice on how serious this will be to repair? Anything helps
