wheelhorse66 10 #1 Posted November 19, 2014 Can I put a starter generater on a 12 hp kohler? Share this post Link to post Share on other sites
JustinW.73 224 #2 Posted November 19, 2014 Whats the model #. Is there a regular starter on it now. Share this post Link to post Share on other sites
squonk 41,746 #3 Posted November 19, 2014 There is one on my 1267 1 Share this post Link to post Share on other sites
wheelhorse66 10 #4 Posted November 19, 2014 (edited) Yes it's a starter on it now. It's not on no tractor yet just getting it ready to put it on one but I like the generator starters better. Edited November 19, 2014 by wheelhorse66 Share this post Link to post Share on other sites
Geno 1,929 #5 Posted November 19, 2014 They are nice and quiet, sure, you can do it. Share this post Link to post Share on other sites
wheelhorse66 10 #6 Posted November 19, 2014 Ok thinks I'm going to put a generator on it then Share this post Link to post Share on other sites
rmaynard 15,767 #7 Posted November 19, 2014 Couple of things that I would check first. Make sure that there is enough room between the engine and the gas tank for the generator to fit. You will need the proper mounting and adjusting brackets to afix it to the engine. You will possibly need a different blower cover that does not have a hump for the starter Bendix. You will need a pulley to mount onto the flywheel. You will need a belt and a belt cover. If you are going to use the starter/generator as a generator as well, I would recommend removing the stator from behind the flywheel if the engine has one. If you are only using the S/G as a starter, then the stator (if you have one) can remain and be attached to the regulator/rectifier for DC power and charging. Share this post Link to post Share on other sites
wheelhorse66 10 #8 Posted November 24, 2014 I'm planning on rewiring everything were I can use the generator for charging power Share this post Link to post Share on other sites
"D"- Man 827 #9 Posted November 24, 2014 I have heard that the starter/generator may not be powerful enough to turn the 12 HP engine over, might want to check first, Mark. Share this post Link to post Share on other sites
Fordiesel69 263 #10 Posted November 25, 2014 If working properly, and the compression release is ok, then yes it will work perfect. Often there is issues with the compression release being worn out, and not picking up the valve enough, or the motor is weak from an internal problem. Share this post Link to post Share on other sites
