Electro12WH
Kohler Cough
Electro12WH
I have had an ongoing issue with that high speed miss, stumble, cough that is common to K series engines. Yes, I know it is normal, but annoying. Any ideas on how to get rid of it? I have changed to an Autolite plug, no luck. Is this a carb. issue? Electrical? Every Kohler I've had did this.
big mike
In all the Kohlers I have had(30-40) the carb problems are usually solved with a soaking in the carb cleaner can and a new kit.
A high speed stumble sounds like a carb issue.
