dave s 0 #1 Posted October 15, 2008 The part number on the belt I removed is Unimatic A-101, is this a WH. number? Thanks dave s Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #2 Posted October 16, 2008 This is on your 520-HC, right? (it helps to remind us what you have - or put it permanently in your signature.) The number you posted is not Toro/WH. Which belt do you need (deck drive or blade drive) and what size is the deck? (or what is the model number of the deck?) Share this post Link to post Share on other sites
dave s 0 #3 Posted October 16, 2008 Sorry about that . TT. The # on the deck is 1548SC01-----13812, the belt is the drive belt off the engine to the mower . dave s Share this post Link to post Share on other sites
Duff 206 #4 Posted October 16, 2008 Sorry about that . TT. The # on the deck is 1548SC01-----13812, the belt is the drive belt off the engine to the mower . dave s If the deck is a rear discharge, the Toro belt number is 108834. If it's a side discharge unit, then the number is 102742. TT may want to double-check me on these..... Duff :banghead: Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #5 Posted October 16, 2008 That should be the 102742 (103 1/4" X 1/2") which has superceeded to 94-2501 and should be right around $24 from Toro. Duff - 15-48SC01 is a dead give away on the deck. The "48S" is the width of cut and the discharge type. (reminder - there wasn't any 48" rear discharge decks) Share this post Link to post Share on other sites
Duff 206 #6 Posted October 20, 2008 Duff - 15-48SC01 is a dead give away on the deck. The "48S" is the width of cut and the discharge type. (reminder - there wasn't any 48" rear discharge decks) Thanks, TT! Little by little I'm learning the ins and outs of these machines! Duff :banghead: Share this post Link to post Share on other sites
