rmaynard 15,509 #151 Posted March 5, 2015 Looks great Brian...as usual. [emoji106] Share this post Link to post Share on other sites
Ken B 3,164 #152 Posted March 5, 2015 Its always a pleasure when you get to see a Master doing his thing! Share this post Link to post Share on other sites
dclarke 4,032 #153 Posted March 5, 2015 Good work, Brian! Share this post Link to post Share on other sites
octfst 378 #154 Posted March 5, 2015 looks good. Thanks for letting us follow your build. Share this post Link to post Share on other sites
buckrancher 2,679 #155 Posted April 24, 2015 Made a new tail shaft gear for the output shaft on the transmission I bought a gear that was longer than the original and cut It down to the length I needed then I had a coworker who runs our wire EDM machine cut a internal spline to fit the output shaft here's the old gear that I cut off the output shaft new gear this gear now takes up the space that gave me the slop in the original trans setup I will use a harden washer and bolt to attach to output shaft Brian 5 6 Share this post Link to post Share on other sites
rmaynard 15,509 #156 Posted April 24, 2015 It somehow seems unfair that you have better toys than me. As usual, great job Brian. 2 1 Share this post Link to post Share on other sites
cstempert 27 #157 Posted April 24, 2015 Brian Looks great That arrangement is similar to the original where the splined shaft would have used a speedometer gear and then a slip yoke retained by a bolt/washer to hold the bearing and shaft in place Hopefully there's enough room for the bolt inside the secondary case Share this post Link to post Share on other sites
buckrancher 2,679 #158 Posted January 14, 2019 finally getting back on this project I'll see what I can do with this hood 3 7 Share this post Link to post Share on other sites
dclarke 4,032 #159 Posted January 14, 2019 I've been wondering what you've been doing to it, Brian. Glad you're back working on it. 1 Share this post Link to post Share on other sites
AMC RULES 37,130 #160 Posted January 14, 2019 GO BRIAN GO! Share this post Link to post Share on other sites
buckrancher 2,679 #161 Posted January 14, 2019 I made a form from a couple of 2 x 4 's of the front corner of the hood put a plastic bag over it laid up two layers of 6 oz fiberglass cloth then married it into the hood on the broken corner then added two layers of fiberglass mat to build the thickness up Brian 7 3 Share this post Link to post Share on other sites
Pullstart 62,905 #162 Posted January 14, 2019 So glad to see this post, quite a marvel of work so far Brian! Share this post Link to post Share on other sites
buckrancher 2,679 #163 Posted January 18, 2019 block sanded and cut to shape should have it ready for primer soon brian 8 6 Share this post Link to post Share on other sites
19richie66 17,508 #164 Posted January 18, 2019 Very nice! That's probably stronger than it was from the factory. Share this post Link to post Share on other sites
buckrancher 2,679 #165 Posted January 20, 2019 I believe it's ready for some primer all holes have been fixed 4 12 Share this post Link to post Share on other sites
dclarke 4,032 #166 Posted January 20, 2019 Lookin good Brian! 1 Share this post Link to post Share on other sites
ebinmaine 67,581 #167 Posted January 20, 2019 That hood looks fantastic Brian! I'm super impressed, to say the least. 1 Share this post Link to post Share on other sites
Shynon 7,459 #168 Posted January 20, 2019 Looking good 2 Share this post Link to post Share on other sites
AMC RULES 37,130 #169 Posted January 20, 2019 Best thread going... oldest too. 1 2 Share this post Link to post Share on other sites
buckrancher 2,679 #170 Posted April 10, 2019 got the transmission back together 3 12 Share this post Link to post Share on other sites
Sparky-(Admin) 21,326 #171 Posted April 10, 2019 Definitely a nice build going on here, no cutting corners. Impressive! 2 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,330 #172 Posted April 11, 2019 This all looks very familiar to me. Coming along nicely. Will this one be at the big show in June? 1 Share this post Link to post Share on other sites
buckrancher 2,679 #173 Posted April 11, 2019 34 minutes ago, stevebo said: This all looks very familiar to me. Coming along nicely. Will this one be at the big show in June? no not this year I have too much going on right now Brian 1 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,330 #174 Posted April 11, 2019 I may be bringing mine down this year... I have some extra parts and part numbers if you need anything let me know. I rebuilt the rear with new seals and bearings. I have all sorts of photos of the process too. Let me know. 4 Share this post Link to post Share on other sites
buckrancher 2,679 #175 Posted May 27, 2022 motor rebuild is done 3 10 Share this post Link to post Share on other sites
