Nick P.
Pop's 875
Nick P.
875 bought new by my dad and now mine.
I learned to drive on this when I was in 6 th grade!
Pop ran a Parker sweeper tow behind the rear discharge deck.
Still used for mowing,
No winter duty. It retires to the garage after fall leaf mulching.
Nick P.
post-13606-0-25023000-1414378099_thumb.j
  • Like 7
Molon_Labe
That's a great story and a very nice old Horse there. Thanks for sharing the memories and the pic, looks great!!
JERSEYHAWG /  Glenn
Nice, the story and your wheel horse. Memories,,,,,,,,,,,
Glenn
KyBlue
That's a wonderful story! Thank you for sharing... :)
Tankman
Thanks for sharing the memory and showin' off the great lookin' Horse!
The RD deck and Parker sweeper are a great combination. Used the same setup forty years ago.  :)
AMC RULES
Pop's old  :wh: is still hanging tough.   :handgestures-thumbsup:
Ken B
Always nice too hear of an original owner tractor being passed down. Your 875 is real nice, has it been restored or is it all original?
Geno
Nice tractor Nick, nothing like having dads old horse.  :text-+1:
KC9KAS
Very nice looking 875, and you have the history behind it!
I have a 875 that I use to mow with every week. My wife kind of calls this "her" tractor!
Nick P.
Thanks all, what a nice reception for the 875.
Looking at a RJ today and was surprised to see it has a Clinton engine with a nice original looking louvered air cleaner can on it? Thought it would have had a Kohler.
I am thinking of buying it, the governor stem has disappeared inside the crankcase and might have some carb issues.
I am guessing it is a late 1950's model with plastic coated steering wheel, agri lug tires and steel seat with Wheel Horse stamped on the front nose of the hood.
Some reason the owner cut the drivers end of the hood off to access the engine?
Advice on year or value?
AMC RULES
Would help to see a pict.    :eusa-think:
  • Similar Content
    • dannyo
      By dannyo
      Hi all.  I am new to the Wheel Horse world and I have a question about attaching a tiller to my 875 before I start spending money.  Based on what I've read so far, it sounds like I can use the RT-366 tiller without having the 8-3311 PTO assembly, is this correct?  If so, does the RT-366 belt attach to the hydrostatic motor if there is a double pully (#6887) installed?
    • D_Mac
      By D_Mac
      Picked this up today because I wanted the deck for my 875. The 875 has no deck so I figured this one is better then none at all. Question is what do I do with the rest of it??? 875, was told the engine needs rebuilding. Been sitting in a barn last 20+ years. Steering wheel is broke. Both front tires are shot and coming off the rims. Original paint. Plow needs the arm to turn the blade. Its repaired in a fixed position. Worth more in parts or as whole? Not sure I want a big project. What do you all suggest???
    • KC9KAS
      By KC9KAS
      My 875 is missing the small spring that is attached to the cam/neutral plate.
      The part number is 1230 and NLA.
      Anyone have one or know the dimensions of the spring?
      Thank you!
    • KC9KAS
      By KC9KAS
      ISO of hydro motion control lever bushings.
      These appear to be parts # 5666 (nylon) need 2, # 5983 (Nyliner) need 2, # MW2195 (bronze) need 1.
      Please PM me here.
      Thanks in advance.
    • admin
      By admin-(Admin)
      1 page 196.25KB
      1 page 82.24KB
      Dated February 17, 1965
      232613 Kohler belt nla Use 231605
      232613 - Gates 7320 .41"x32.58" 36 degree or Napa 25-7320 .41"x32.58" 36 degree
      231605 - Gates 7315 .41"x32.08" 36 degree or Napa 25-7315 .41"x32.08" 36 degree
      1964 model 854
      1965 model 855
      1965 model 875
      Starter/generator belt
      Kohler 10hp, 12hp - 235262 (7345 Gates .410" x 35.09" 36 degree) (25-7345 Napa .410" x 35.09" 36 degree)
      Wheel Horse 1593 (3L x 34.4") - nla (Gates replacement 6735 3/8" x 35" 38 degree)
      1964 model 1045
      1964 model 1054 - Not in PSB - Wheel Horse # 1593 nla {3Lx34.4"} - Gates 7340 .410"x34.58" 36 degree or Napa 25-7340 .410"x34.58" 36 degree
      1965 model 1054A - Not in PSB - Kohler 235262 replaces 235528 [.41"x35.09" 36 degree] - Gates 7345 .41"x35.09" 36 degree or Napa 25-7345 .41"x35.09" 36 degree
      1965 model 1055
      1965 model 1075
