Bach-Ed
tie rod adjustment
Bach-Ed
I am replacing the tie rods on my 857.  On cars there usually is a slight toe in.  Should I have some toe in or is straight ahead OK.  Or am I making mountains out of molehills, after all mine won't be going twenty or more MPH.
Ed
cleat
According to the setup manual for the 520 you want a 1/8" toe in at the front edge of the rim 6" above the ground.
Cleat
  • Similar Content
    • rustyedge1
      By rustyedge1
      Going to need tie rods, one of mine came apart today. Was wondering if anyone could recommend someone ?
      Would settle for good used parts if available from someone. Dose anyone know the part numbers for my machine.
      Thanks in advance for the help.
      Dan
    • Ifixoldjunk
      By Ifixoldjunk
      So I was out mowing the other day with my 310-8 and somehow snagged my wheel in a hole in the yard. Anyways I pretty much destroyed my ball joints. I've since replaced the tie rod with junkyard parts but I was wondering if anyone's found a heavy duty aftermarket replacement for the tie rod assembly.
      Like would generic adjustable go-kart tie rods do the trick?
    • Patrol D-6
      By Patrol D-6
      Hello,
         Does anybody have any information on NOS TORO PART NO. 112773 TUBE for the Tie Rods ????  These are discontinued.
