Sparky-(Admin) 26,205 #1 Posted October 13, 2008 Heres a few pics of how the snowblower hooks up on an Attach-a-Matic era tractor. this particular one is a 1988 42" single stage blower on a 1989 312-8. Mike........ 5 1 Share this post Link to post Share on other sites
Craig Arndt 6 #2 Posted October 27, 2008 Really helpful, sure wish I would have saw this before I spent an hour trying to figure it out. Thanks a lot. Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,926 #3 Posted October 27, 2008 Brian, You definitely need to spend more time here on RS - it's the Wheel Horse place to be for this kind of stuff. :banghead: Share this post Link to post Share on other sites
stumpkicker 0 #4 Posted January 12, 2009 I am new to this site as of today! So I am hoping this is going to Sparky! I am Jimmy G I have a snow blower mounting question please. On your snow blower install pictures the second and third picture where the rod with the flat steel hooks to the (Black bracket) I don't have that hook up on my tractor. Was wondring if you might know the name of the bracket or dementions so that I might make one. I had it all hooked up untill I tried to find out where to attach the long pipe with the bracket at the end then I gave up and put the plow on instead. Thanks Hoping I am not a bother as I am new here. Thank You JimmyG Share this post Link to post Share on other sites
Sparky-(Admin) 26,205 #5 Posted January 12, 2009 The part your missing is called a Lift Flag. Somewhere on this site are dimensions for it.....just cant remember where. If I find the post with dimensions I'll add it here. Mike....... Share this post Link to post Share on other sites
Duff 207 #6 Posted January 12, 2009 I am new to this site as of today.......Thanks Hoping I am not a bother as I am new here. Thank You JimmyG JimmyG, ! Asking questions or offering help/advice is never a bother - it's what makes this place what it is - the best goldarned tractor site on the internet! :horseplay: Glad you found us! Someone will be along to answer your question and help you out, I'm sure. Again, ! Duff :thumbs: Share this post Link to post Share on other sites
WheelHorse_of_course 101 #7 Posted February 18, 2009 Flag measurements http://www.wheelhorseforum.com/index.php?showtopic=7227 :thumbs: Share this post Link to post Share on other sites
WheelHorse_of_course 101 #8 Posted February 18, 2009 And to bring everything together in one place here is the belt routing info for a blower: http://www.wheelhorseforum.com/index.php?showtopic=5522 :horseplay: :thumbs: Share this post Link to post Share on other sites
Sparky-(Admin) 26,205 #9 Posted November 3, 2013 Its getting to be that time of year that the blower questions start to show up.......... Mike.......... Share this post Link to post Share on other sites
thehorse 221 #10 Posted November 7, 2013 Quick question.... What do you hook the lift assist spring to...I'm taking pics this year!!! Share this post Link to post Share on other sites
squonk 47,879 #11 Posted November 7, 2013 (edited) Spring hooks to an eyebolt which goes through the hole on the flag (adjustment point) and the footrest/floorboard rod on the front end. Edited November 7, 2013 by squonk Share this post Link to post Share on other sites
Scotsman 46 #12 Posted December 1, 2013 On a related note,I just finished installing my snowblower on my 312-8 which was going smooth until my chute cable snapped and unraveled. Then I spent 2 hours trying in vain to put it back on and rotate the chute . After all the stuff I have done to my 312-8, it's madness! So before I posted I did something I'v been meaning to do for a while and took off the 4 chute bolts and greased it nicely. Mine is the single stage. i'll put some pics on tomorrow. Share this post Link to post Share on other sites
Scotsman 46 #13 Posted December 1, 2013 I forgot to say I haven't figured out how to run the cable. Does anyone know how to wrap the cable through the hole and around the rod in the correct way? Thanks in advance. It seemed so simple,maybe it will be after I see the correct way. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,446 #14 Posted December 1, 2013 Last year for the cable was 1990. Here is a 1984-87 manual which had a spool on the crank. The 1st models did not have a spool and the hole was in the crank. Hope this is the style you have. Here is an earlier manual with different illustrations Garry 1 Share this post Link to post Share on other sites
wallfish 20,494 #15 Posted December 1, 2013 (edited) The spool or rod pulls one side as it lets out the other. Attach one end of the cable to the chute but leave an extra couple of inches for final adjustment. Rotate the chute by hand all the way towards the opposite side of which ever side you just attached the cable to. Route the cable to the spool or rod and wrap it one time around the spool and feed the cable through the hole. Keep in mind that you want the handle to turn the same direction as the chute needs to move. While keeping tension on the loose cable, rotate the spool or rod until the chute travels the full distance to the other side. Wrap the cable one more time around and route the cable to the other attaching point on the chute and lock it down. Test the rotation of the chute to make sure it can travel the full distance. Tighten up the cable tension if necessary. Cut off extra cable at attaching points after everything is working correctly. It can be a pain to keep enough tension on the cables while spooling them. It's unnecessary to wrap the spool or rod one extra time with the cable but it leaves enough spare cable to make adjustments in the future if needed. A little grease on the cable and the friction points on the chute helps smooth it all out. Edited December 1, 2013 by wallfish 1 Share this post Link to post Share on other sites
Scotsman 46 #16 Posted December 1, 2013 Ok its raining today. Ill try it tomorrow. Thanks alot I really appreciate it. Share this post Link to post Share on other sites
Scotsman 46 #17 Posted December 7, 2013 Thank you Gary,and John. I really appreciate it. You guys are what make this site the best. And stumpkicker if you read this send me a message how to contact me if you want a lift flag. I have an extra one. Everyone has been so helpful to me I want to try to help out someone else. If you send me the shipping cost I can send you the lift flag. It's up to you,let me know. Matt 1 Share this post Link to post Share on other sites
Uncle Buck 246 #18 Posted December 7, 2013 Thank you Gary,and John. I really appreciate it. You guys are what make this site the best. And stumpkicker if you read this send me a message how to contact me if you want a lift flag. I have an extra one. Everyone has been so helpful to me I want to try to help out someone else. If you send me the shipping cost I can send you the lift flag. It's up to you,let me know. Matt I know just how you feel. I was a long time lurker that has only recently become active on the site and I too have been totally impressed with the help I have gotten from the membership here. 2 Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #19 Posted December 15, 2013 From 5 years ago: 1 Share this post Link to post Share on other sites
Scotsman 46 #20 Posted December 15, 2013 Well thanks for the help guys I got the chute cable sorted out. Now today I was so exited to use it,but it would not throw the snow. The auger stopped turning. Its a 312-8 It should be plenty of power. So I tried to push the heavy wet snow with the snowblower , and my cotter pin on the lift arm under the snowblower kept ripping out. Its the biggest cotter pin that will fit. I have a plow, its a 6-2132 will it fit my late 80's 312-8? Share this post Link to post Share on other sites
thehorse 221 #21 Posted December 15, 2013 Your snow removal experiences sound like mine! First time blowing snow this season and the key on the Marin blower pulley sheared off. Off to Ace....man I love that place! Then last night the lift arm was not functioning. The hitch pin must have rotated around some or scraped it off the edge of one of the driveways. Well thank God I've been getting an extra when I replace something. Put a thicker washer above the hitch pin and was back in business! 1 Share this post Link to post Share on other sites
thehorse 221 #22 Posted December 15, 2013 Oh...and just go a little slower and take half the width after you get that first pass. I'll often hold the blower up on the first pass when it's heavy, let the chains dig me back and then go for it again. 1 Share this post Link to post Share on other sites
redidbull 54 #23 Posted December 16, 2013 Here is a list of Snow Attachment Manuals. Jim http://www.scribd.com/doc/47347681/wheelHorse-Snow-Attachments-Manuals 2 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,587 #24 Posted December 16, 2013 From my 416-8. Any questions ask. I will post more pics from book. Glenn 1 Share this post Link to post Share on other sites
Scotsman 46 #25 Posted December 17, 2013 Thanks for the info and teqnique tips. always appreciated. when I figure out how to give positive feedback you all will be getting some. Share this post Link to post Share on other sites
