waterlooboy2hp
Ready For Snow
waterlooboy2hp
I have 6 snow blowers. Just finished restoring and modifying  this one. Can`t wait to try it out.  Here are the before and after photos. -- John
  • Like 5
AMC RULES
Beautiful job for sure.   :handgestures-thumbsup:
Digger 66
WOW !
I thought I was the only one using a blower that's as old as me  :ychain: .
Beautiful job on the resto !
Geno
Very nice, new engine too!     :text-woo:
Ed Kennell
:WRS:    Keep those blowers ready....sounds like we may need them in York Co this winter.
shallowwatersailor
Nice restoration on the Lombard. Did you modify the HF engine for cold weather?
RMCIII
That is AWESOME!!! Post that on "What will you be using to clear snow 2014" thread!....... Definately want to see a video of that in action!
Rob
waterlooboy2hp
No, not as yet. The original engine was a 2 shaft Tecumseh H-60. The new engine is a 346cc 11hp unit.  I modified it into a 2 shaft engine.
I just put a Predator 212cc engine on a Jake Imperial 626. I did winterize that one.
 Instead of re-jetting the carb and or, adding a heat box, I bought a carb with the adjustable low speed jet. I opened the stock .028" high speed jet to .0469" (#55 Drill).  I then added an adjustable high speed needle to the carb. I also designed an adjustable system to draw hot air from the muffler, directly into the carb, without the need for a heat box.  Can`t really put it to a test, until I get some cold  weather. Right now, I have the engine running so smooth, that it sounds like an electric motor.  If the cold weather test works out, I will do the same to the 346cc engine .
As for the Lombard name, all the ID tags and the decals on mine, say it was made by American Lincoln Corp.. I know that American Lincoln bought all, or part of Lombard. However, I have never been able to find anything that says the Lombard ever made snow  blowers at all. Have only found 2 others like mine on the whole internet, and both had American Lincoln decals on them. -- John
Edited by waterlooboy2hp
Zeek
Stop it . . . snow sucks  :kbutt:
Those are some cool looking blowers I'd like to try out myself!  Nice job  :banana-rock:
Edited by Zeek
