saminmn 17 #1 Posted October 15, 2014 I have a 89 Ford yt16H that the trans seems to be slipping. I have changed the fluid,filter, and put on new belts.They are all tight & everything seems ok .Sometimes its ok when I first start out but gets worse as you go along. Any suggestions? Share this post Link to post Share on other sites
shallowwatersailor 3,213 #2 Posted October 16, 2014 How bad was the fluid that drained out? If you still have the old filter, cut it apart and look inside. The Eaton 850 and parts are not available, nor is its replacement, the 851. Best thing is to look for a parts tractor. Other manufacturers, including Simplicity, used it as well so that does broaden the search. Share this post Link to post Share on other sites
saminmn 17 #3 Posted October 16, 2014 thanks for info. I do not have the oil anymore but might have the filter.I will cut it and see. Share this post Link to post Share on other sites
