saminmn
Ford Eaton 850 trans.
saminmn
I have a 89 Ford yt16H that the trans seems to be slipping. I have changed the fluid,filter, and put on new belts.They are all tight & everything seems ok .Sometimes its ok when I first start out but gets worse as you go along. Any suggestions?
shallowwatersailor
How bad was the fluid that drained out? If you still have the old filter, cut it apart and look inside.
The Eaton 850 and parts are not available, nor is its replacement, the 851. Best thing is to look for a parts tractor. Other manufacturers, including Simplicity, used it as well so that does broaden the search.
saminmn
thanks for info. I do not have the oil anymore but might have the filter.I will  cut it and see.
