Ethan and Randies horses
brinly plow or not?
this looks like a brinly but has no tags so is it a brinly or not?post-13882-0-73351000-1413161192_thumb.j
groundhog47
That sorta looks like a Wheel Horse plow believe Brinly made some of them, unsure, could say better if saw plow adjustment. Coulter wheel attaches differently to beam than newer Brinly. Frog looks same. The straight beam throws me too. There is one in MANUALS sect that looks like it but doesn't specify from Brinly.
Found this site for Ohio Steel Fabricators: http://www.stevenchalmers.com/Gravely/A76/5_Plow.shtml
so they must have made it instead of Brinly. Picture they have looks like earlier Wheel Horse depth adjustment set up.
Quote from another tractor site: "Brinly plows .... along with some other implements they sell ... are manufactured by Ohio Steel Fabricators located in Columbus Ohio. Sometimes you will see painted red plows identical to Brinly with a Ohio Steel Fabricators decal on the beam."
 Both  below from this site, brochure on page 6 from here: http://www.stevencha...76/5_Plow.shtml5_Plow.jpg
Edited by groundhog47
the adjuster is just a bolt and nut
groundhog47
Check pics in post 2.
CasualObserver
Brinly and Ohio Steel are two separate and distinct companies.  Both made the equipment under their own respective names as well as making branded equipment for companies like :wh:
That Green decal is an Ohio Steel decal.  They made it.
