slammer302 2,155 #1 Posted October 12, 2014 I'm working on restoring a 36" RD deck for my daughter's 857 and I'm going to use POR15 rust preventive I've heard lots of good things about it but I'm not sure of what color to buy I'm thinking clear would be a good choice but am I over looking something on this choice Share this post Link to post Share on other sites
bowtieguy 334 #2 Posted October 12, 2014 I use the "silver" color....use gloves and don't breath it....just sayin'! Share this post Link to post Share on other sites
slammer302 2,155 #3 Posted October 12, 2014 Thanks Frank Share this post Link to post Share on other sites
bmsgaffer 2,046 #4 Posted October 12, 2014 From their data sheet: Thin, covering coats are best; POR-15 will accept all top-coats including lacquer-based paints. POR-15 is a great concrete sealer and is impervious to fuels, battery acid, oils, etc. GLOSS BLACK** - use on frames, floorboards, fenders, engine compartments, trunk areas GRAY - use for marine and industrial applications, also excellent on concrete SILVER - contains aluminum and can be used on badly rusted steel to fill small holes and add strength. CLEAR - dries to a perfect satin gloss. Use on exterior surfaces before final painting. SEMI-GLOSS BLACK* - for frames, chassis, firewalls, inner fenders that demand original semi-gloss look * Keep in Mind that although we suggest our colors for different applications, POR-15® is versatile and any color can be used in any situation. Share this post Link to post Share on other sites
