slammer302
POR15 COLOR?
slammer302
I'm working on restoring a 36" RD deck for my daughter's 857 and I'm going to use POR15 rust preventive I've heard lots of good things about it but I'm not sure of what color to buy I'm thinking clear would be a good choice but am I over looking something on this choice
bowtieguy
I use the "silver" color....use gloves and don't breath it....just sayin'!
slammer302
Thanks Frank
bmsgaffer
From their data sheet:
Thin, covering coats are best; POR-15 will accept all top-coats including lacquer-based paints.
POR-15 is a great concrete sealer and is impervious to fuels, battery acid, oils, etc.
  • GLOSS BLACK** - use on frames, floorboards, fenders, engine compartments, trunk areas
  • GRAY - use for marine and industrial applications, also excellent on concrete
  • SILVER - contains aluminum and can be used on badly rusted steel to fill small holes and add strength.
  • CLEAR - dries to a perfect satin gloss. Use on exterior surfaces before final painting.
  • SEMI-GLOSS BLACK* - for frames, chassis, firewalls, inner fenders that demand original semi-gloss look
* Keep in Mind that although we suggest our colors for different
applications, POR-15® is versatile and any color can be used in any situation.
