AJ_Thanatos
Wheel weights!
Geno
What better than to spend some QT with dad anytime, let alone making Horse stuff.  And just where did you get all that fancy equipment?  :popcorn:
Edited by Geno
AJ_Thanatos
Dads the foreman of the tool and die room! Lucky me!
Geno
Hard telling what I would have if that were my case.  :laughing-rolling:
AJ_Thanatos
Second lathe getting set up to turn weight #2
  • Like 5
Geno
Thanks so much for the pics AJ, very cool!  :text-+1:
AJ_Thanatos
AMC RULES
Looking really good...   :handgestures-thumbsup:
any idea of the weight when finished?
chipwitch
Severed fingers would be my guess!  :laughing-rolling:
Sorry, Geno... jk
AJ_Thanatos
They should weigh about 80 ish each
AJ_Thanatos
  • Like 4
AJ_Thanatos
Just need to drill some holes and counter bore them. And slap some shiny paint on them. And on the tractor!
  • Like 8
AMC RULES
AWESOME!  :handgestures-thumbsup:
Make me a set too.
KC9KAS
Wow, that is so neat.
We have a Tool & Die department (at work) with all the goodies too.
I have wondered what it would cost to have a set of weights made like yours!
They are pretty "proud" of their work & products, so I probably couldn't afford to have them made even with an employee discount!
chipwitch
Those are really nice weights.  Very sharp.
I've thought about making my own, but the cost of steel is about what you could get the cast weights for use.  Of course if you have a spare hunk of 11" round rod laying around taking up space, what the heck... nothing like a custom look.
Geno
Looks really good AJ.  :text-woo:
squonk
Baby Moons!  :thumbs:
KC9KAS
Yeah, for a little more weight, you could have made the outside into a dome.
AJ_Thanatos
Let's not get crazy.. Im lucky I pulled this off on a lathe. But they should be heavy enough. Per my calculations they should be about 87 lbs. Each
And thank you all. It wouldn't be possible without my Dad. It was really nice to spend the day with him in his world.[emoji2]
Edited by AJ_Thanatos
3Six
Awesome!
rollingflat
LOVE EM !!
JERSEYHAWG /  Glenn
AJ...BIG THANK YOU.....that was so cool. Enjoyed the machine shop pics. And the weights are beast.
Glenn
tbarnhart
Awesome weights. I was curious how thick they are. I made something similar in a different way. We have a large fabrication shop nearby that keeps thick plate and has the equipment to cut any shape. I went to them and bought 2 circles 11.5 in. in diameter that were 1 in thick and 2 that were 10 in. in diameter and 2.75 in thick. I centered the smaller/thicker ones on the larger ones and welded them together, then welded four 3/8 bolts to the back at the right spacing  to match the holes in the wheels. They weigh a little over 90 pounds and sit about flat with the outside of the wheel. I think they look a little odd with just a flat surface and thought about some sort of logo decal, but it would probably just get scratched off. The 160 is more stable and will pull the plow or grade the drive like never before.
chipwitch
How about a cnc WH logo hub?
AJ_Thanatos
I think I'm going to look on Terrys site for a big horse logo.
The entire plate thickness is 3.5"
