Bobie01
Where could I buy?
Bobie01
Hello
after the swap from a KT17 to a K301in my C165, the choke cable on the throttle cable are to short. But where can I find where can I find just the cable without lever?In a lawnmower shop or at an industry specialist? Where did you buy things like this?
Desko
Tractor supply, lowes, or sears but to get OEM id go to partstree
Bobie01
I ask to mower and tractor dealers they don t have cables. the industrie parts services was closed on friday I have to try on monday
meadowfield
You can buy the whole thing with a lever here in the uk for £6 or €8 that how I got new cables.
Bobie01
oh an then you cutthe lever an fix them on the original lever?
meadowfield
That's it, throw the lever away. Mine were 1.5m long so needed cutting down.
Bobie01
ok I will check it on monday :)
daveoman1966
Don't pitch the OEM levers.  Put the lever in a vise to hold it and just pry open the jaws that crimp the cable.  'Z' bend another longer cable and put it back in the same lever.  You can 'crush' the jaws back to clamp the cable again.  I've done this 50 times or more....
Bobie01
-i had phone to the local toro Dealer an ask if they had an Unisersal cable. Yes they have for a piece price of 4(!!!) euro!!!nice ;)
Bobie01
I have mounted the gas cable on the engine. I bought the engine 1 year ago, but I think the speed controll(I dont know the English term) dont operate well. I don t think that it s broken because the previous owner had a broken axle. Does anybody know how to adjust it ?
Bobie01
I google it. is the governor which doesn t work well... any ideas?
