saguaro
Engine temperature
saguaro
The paint I want to use on the crank case is only good up to 200 degrees. Does the case get that hot? Cylinder/head temps? It's an HH60
TT
I have painted several engines with good old Krylon aerosol enamel and have only see it burn or discolor around the exhaust port so far. (which is exactly what most original engines look like after a short time too.)
sorekiwi
In my experience even the engine paints will burn off around the exhaust port. However the rest of the area around the cylinder and the head itself seem OK.
saguaro
Thanks. Both of you. Never seen an unburnt exhaust either.
sorekiwi
By the way, the above comments apply to RED paint only, anything other than RED qualifies it as a b@stard child, and all warranties are null and void!
:banghead::USA: :omg:
saguaro
:banghead: Youz Just Jealous :USA:
It'll look good.
