sluggo
Wheel Weights for Snow Plowing
WheelHorse79
HDAP stands for Heavy Duty All Purpose.  These tires have more aggressive tread than turfs, but less aggressive than ag tires. They are found primarily on ATVs, but there are some tractor models that come with them as standard (i.e. JD X530 series).
bmsgaffer
I believe HDAP is a John Deere specific term for their "upgraded" tire set.
HDAP are just Carlisle HD Field Trax tires that JD sells at huge markup
The Carlisle All Trails are very similar though and available in more sizes that fit the WH's.
SirFuego
FWIW, you don't "need" to put fluid in your tires, put on aggressive tires, or even have wheel weights (unless perhaps you are a really small guy).  Don't get me wrong, they will help traction, but you can definitely get by without them.  The setup on my 244-5 is just a plow with just chains on turf tires and I haven't felt like I was lacking traction the past few Buffalo winters I've used it with (disclaimer: I use it on a long, paved, mostly flat driveway).
The key is to plow with the storm (when we get 12+", I'm usually out there at least twice, but if it's fluffy snow, I might just wait till its done) and not try to take too much snow with the blade.
Edited by SirFuego
PaulC
  Quote
I also agree with this statement and I also deal with the Buffalo snow! I too have a pretty flat asphault/concrete driveway and for the past two years have only put chains on my 312's with my 42" blower. My blower will bog before I loose traction for the most part.
I will say though now that I built myself a rear hitch I am thinking about adding some plate weights to the rear this year just to see how much of a difference the weight makes.
squonk
You would not believe the difference filled tires make. Once you get a head of steam, The momentum of the rolling fluid will shove the tractor an extra foot or two when hitting a snow bank. I plowed snow for 54 years with out filled tires, but after doing it, I would not go back to unfilled.
Edited by squonk
doc724
I am not a big proponent of filled tires, but I know that many of you are and have been using that technique successfully for many years.  It has been over 40 years since I took Engineering Mechanics, but I do remember that rotational inertia must be counterbalanced by the strength of materials.  Inertia can be your friend as well as your enemy.  It is a good thing the designers of the WH Unidrive way back in the 50's over designed the pinion and differential gears or else those tranny's would be littered with broken gear teeth.  Weight placed close to the center of rotation is a bit easier of the drive train.  But hey, who am I to argue with success.  If it works, go for it!
  • Like 4
SirFuego
I wish I had a blower on mine.  The plow is nice, but the snowthrower just seems like it'd be easier since I don't need to "plan" where to put all the snowpiles.  I've been looking for one, but haven't come across one and was too slow for one out in Darien (all the ones I found locally require the horizontal shaft pto and my 244-5 has the vertical shaft pulley).  Let me know if you happen to hear of something (I've been checking craigslist daily).  Sorry for the hijack...
Oh yeah I don't doubt that at all.  Offroading (Jeeps, buggies, etc) is a hobby of mine and I know it's common to do the same in those for extra traction (if your drivetrain can handle the additional rolling mass).  All I was saying was that you don't absolutely need to do all of that to plow well -- even in areas like upstate NY and MI that get a good amount of snow.
Edited by SirFuego
PaulC
  Quote
Funny you mention that I just posted one for sale on CL about 2 hrs ago unfortunately its horizontal shaft for 3,4,500 series. I got my blower to scrape like a plow so I have the best of both worlds haha. I have not run a plow but I expect I would much rather run a blower. Hope you find one!!!
Reading comments like squonks makes me want to try added weight but I like my shiny hubcaps so wheel weights are out :laughing-rofl: that's why im liking my idea of plate style weights that will slip onto a bar or tube coming out of the rear hitch, easy on easy off and can keep my bling :woohoo:
SirFuego
Haha.  I actually saw your ad and got excited -- then I looked at the pics and realized it wouldn't work.
The key is to get weight above the rear axle, so the rear hitch idea should work pretty well if the hitch can handle it.  I'm a fatty, so that pretty much counteracts the need for wheel weights, but I know my Dad (who isn't) had no issues plowing with it years before I ever used it.
Edited by SirFuego
pfrederi
When you raise your snowblower and try to back up any grade you will want weights and chains....
  • Similar Content
    • 2drxploder
      By 2drxploder
      looking for a tiller for my 520h as well as some wheel weights. also maybe some good chrome hubcaps
      located in charlotte nc area
    • cbj75
      By cbj75
      I have a 1975 D200 Wheel Horse with front mount dozer blade, package includes Wheel Horse Dump Trailer, 48" belly mower side discharge, Wheel Horse front and rear wheel weights, turning brakes, rear PTO and 3-point to 2" receiver attachment, and Brinley twin disc harrow. Rear luggage/rack carrier, All refurbished, sandblasted and painted Ford red in 2016. Lots of extra Wheel Horse parts included.
      Package price $3000.00.
      Bryce Johnson
      102 Anglers PT
      Mc Cormick SC 29835
      913-638-6788
      IMG_1962.HEIC IMG_1965.HEIC IMG_0279.HEIC
    • Donavon
      By Donavon
      Need ideas to convert my 1054 A Frame plow into a snow blower
      Any idea's?
    • t_furl43
      By t_furl43
      A Wheelhorse C-165 8 speed, nice solid tractor everything works and operates as it should, all lights works(stack will be removed before sale)unknown hours it was only an option for the 165, but the 16hp single lung cast iron K series motor starts right up and runs strong. It will need new motor mounts. Transmission shifts smooth, package comes with plow w/optional down pressure bar if you choose instead of your trunnions chain, a set of tire chains, a set of Toro brand front wheel weights and a set of generic rear wheel weights, and lastly a full set of hub caps that are in decent shape they can be cleaned up, $1000 obo. Would like to sell as package but if the right buyer was interested in the right combo of stuff for the right amount of money we could work something out. Pickup only in Millersville PA 17551
    • OHLB
      By OHLB
      Newbie here. 310-8 won't start. Battery is dated 10/19. Did crank a couple times but started losing ummph. Should I replace it or attempt to charge it? Can't tell if the battery is frozen. Never knew until today that batteries could freeze and that it's dangerous to charge a frozen battery. It's been single digits with wind chill the last couple weeks here.
