Welsh Wheelhorses
Wheelhorse C160
Welsh Wheelhorses
I have began a rather ambitious restoration of a wheel horse c160 which I paid £15 for unseen. When it was collected I found the rear of the transaxle missing around the hitch. A massive lump of fibreglass was unsuccessfully filling the hole. I welded steel plates in the hole and can't get it to seal where the transaxle splits. I am considering buying a sheet of cork gasket to make a thicker seal from, but I want a hitch and am not really happy with it. Ive tested the pump on my c125 and it's really strong. The c160 was outside for 20+ years and the k341 fired up with fresh fuel and a jump lead on the starter! Would anyone have a transaxle ( no pump or motor) spare for sale? I don't need the gears only the casings. The last photo is where I'm at now. Sorry for the long post. I hope share the whole restoration when I'm done, as I've been taking photos as I'm going along.
Many thanks
Thomas
post-12930-0-33726400-1412182348_thumb.j
post-12930-0-20539200-1412182502_thumb.j
post-12930-0-77284400-1412182622_thumb.j
meadowfield
Hi,
hydros aren't too common in the UK - spares are even rarer....  someone might have a whole transmission, failing that maybe change over to a Unidrive....
mark
Welsh Wheelhorses
Might have to resort to fabricating the hitch " pipe" from a bit of pipe to try and make it look original. The welder has seen a lot of use recently fabricated a new deck shell from 3 mm steel:)
If anyone knows of the castings or a whole trans please let me know.May be willing to pay shipping from USA?
Thanks
Thomas
post-12930-0-37525800-1412184034_thumb.j
post-12930-0-99722500-1412184146_thumb.j
post-12930-0-11885000-1412184198_thumb.j
  • Like 4
meadowfield
good work...
might be worth popping over to our sister site myoldmachine.com to say hello and see if anyone can help.... :D
Trouty56
There are rear hitches that bolt only to the axle tubes....not as heavy duty as Scott's but pretty stout....if you can get the tranny to seal.....
Sparky
That deck shell looks incredible!! Well done.
Mike......
Welsh Wheelhorses
Thanks for the replies I will try to repair what I have as the us-uk shipping is so expensive.
Thomas
