Belt slipping, bad bearing, cutting grass sporadically
By
slimkimg, in Implements and Attachments
Similar Content
By Reeferred
Need help,. 244-h model 72041 newer. The drive belt keeps coming off is it to lose, to tight? Any ideas would be great
By Garland Farms
Hi, I finally got my tractor shifting (had to drill a hole in cover and custom install a brake to stop belt from spinning) and now the dang thing won't move unless the now deck is engaged (probably doesn't have anything to do with the mow deck, more to do with the mechanism associated with the lever engaging the deck - that exterior clutch)
Does this sound like a linkage adjust issue or something else? Thanks.
By mr_speegs
So...my 1966 876 Wheel-A-Matic snapped a rod a number of months ago and I've been stumbling through the engine rebuild since. I think I'm finally seeing light at the end of the tunnel, but I may have finally gone in a little over my head. The connecting rod broke as a result of (or cause of) two worn crank bearings. I've removed the bearing plate side, but am a little apprehensive at what I'm seeing on the PTO side. The large valve/timing gear is blocking me from knocking the remaining crank bearing out. Is there any way of me getting that bearing out short of complete engine disassembly?
