aboutime
1981 C-175 8 SPEED
aboutime
I AM NEW TO THE WHEEL HORSE. BUT I PICKED UP TWO C-175 BACK IN JULY ONE RAN AND THE OTHER NEED A COIL. ANYWAY I USE A COIL OFF A GM CAR AND TWO CONDENSERS AND A BALLIST RESISTER, WORKS GET. I HAD TO MAKE A FEW PARTS FOR THE TRACTOR LIKE THE BELT GUARD ,FOOT REST AND THE REAR FENDERS. THE PICTURES WILL HAVE TO COME IN SPIRTS BECAUSE OUR INTERNET IS TOUCHY. post-13501-0-91091200-1409746102_thumb.jpost-13501-0-78310900-1409746137_thumb.j
Geno
Looks like you have some work ahead of you.   You can bring her back to life!    :handgestures-thumbsup:
Hodge71
This is my dream tractor...gonna keep my eyes on this one big time! Do it up reeaalll nice!!
AMC RULES
:WRS:
Jparkes43
one of my favourite tractors being restored there, good luck
aboutime
just to let everybody no that this restore is already done . finished it a few weeks age. but I want to share what I did and how I did it. I made the belt cover out of a Mustang quarter panel. the foot rest was made out of running boards off a chevy pickup the fenders I also made out the running boards. Here is a few pictures.
aboutime
Here a rear  view
post-13501-0-54700800-1410039853_thumb.j
after I got the parts made and got it running, right I took it apart. it came apart pretty easily thankfully.
post-13501-0-43250600-1410039987_thumb.j
posifour11
I like the looks of that!
JERSEYHAWG /  Glenn
Looks good. I like this particular tractor.
Glenn
Geno
You don't mess around do you.  :text-+1:
diggerjames
It looks just like mine does at the moment good luck with your restoration
aboutime
Here is a few pictures of the progress. I started out using Valspar Cut Ruby. I was not to impressed with drying time and overspray. So  I went to Krylon Cherry Red dried faster and very little overspray.
I used Rustleum Almond white on the wheels. Not sure if they needed to be white or off white but the almond looks pretty good.
I had to weld up the center portion due to cracks.
AMC RULES
Looking really good, up on all fours again.   :handgestures-thumbsup:
Geno
He'll be driving it before you know it.   :popcorn:
aboutime
few more progress pictures.
I my still may try and something different with the fenders.
Geno
I like the industrial look.   :handgestures-thumbsup:
aboutime
FEW MORE PICTURES THIS MORNING.
THE TRACTOR HAD A RATS NEST OF WIRING WHEN I GOT IT. THE FIRST OWNER AN A FUSE PANEL 8 INCHES  LONG AND HAD A TRAILER HOOK UP AND REAR SPOT LIGHTS.
I CLEANED IT UP HERE IS FINSHED PICT OF BEHIND THE DASH.
post-13501-0-15431200-1411304648_thumb.j
THIS TRACTOR HAD A CIGARETTE LIGHTER. DOES ANYBODY KNOW IF THIS CAME WITH A LIGHTER OR WAS IT INSTALLED LATER?  I NOW SOME OLDER ONES CAME WITH CIGARETTE LIGHTERS. ANYWAY I HOOKED IT UP.
post-13501-0-55176400-1411304676_thumb.j
HERE IS A PICTURE WITH THE ENGINE INSTALLED. WHEN I GOT THE TRACTOR I WAS TOLD THAT IT HAD NO COMPRESSION. I HAD TO TRY IT FOR MY SELF. ONLY THING I FOUND WAS THAT IT HAD NO SPARK. SO I USED THE IDEA OFF OF BRIAN MILLER WEB SITE. I LEARNED ALOT FROM THAT SITE. TRACTOR FIRED RIGHT UP.
THE ENGINE HAS SOME VALVE SMACKING NOISES I HOPE THIS IS OK. I REALLY DO NOT WANT TO GET NEW VALVES AT THIS TIME. I DID TAKE THE HEADS OFF TO CHECK FOR CARBON. I STILL CAN SEE THE HONING MARKS IN THE CYLINDER WALLS. I ASSUME THAT IS A GOODTHING.
post-13501-0-54853400-1411304725_thumb.j
THE REAREND I CUT THE OLD WHEEL HORSE LOGO OFF OLD PLASTIC FENDERS AND I ALSO REUSED THE LIGHTS. LOOKS PRETTY GOOD FOR NOW. THE REAR PART THAT HAS THE LIGHTS AND LOGO ON IT CAME FROM LEGS OFF A TABLE SAW.
post-13501-0-02200600-1411306370_thumb.j
THE BELT GUARD WAS HOMEMADE THE METAL CAME A 67 MUSTANG QUARTER PANEL.
I USE WHAT EVER I CAN TO SAVE MONEY.
THE NEXT PART IS GOING TO BE THE HOOD "WHAT A MESS".
Geno
Looking better all the time, nice work!  :text-woo:
aboutime
THANKS GENO.
IT HAS BEEN FUN, I REALLY ENJOY RESTORING OLD EQUIPMENT. HERE IS A FEW MORE PICTURES OF THE HOOD.
post-13501-0-55299900-1411942903.jpg3
THE PAINT WAS VERY DIFFICULT TO REMOVE.  THE MORE I SANDED THE WORSE IT GOT. I ENDED UP HAVING TO USE PAINT REMOVER.
THE HOOD WAS NOT PERFECT IT HAD ALOT OF PITS FROM THE RUST. I REALLY DID NOT WANT TO USE BODY FILLER, SO I WILL HAVE TO LIVE WITH IT.
I WILL DO MY OWN DECALS. I KNOW THAT YOU CAN BUY THEM PRETTY CHEAP BUT THIS IS A BARGIN BUILD.
Wishin4a416
Looking good!! Those blackhoods are sharp.
Geno
Looks like the hood turned out pretty good.   :handgestures-thumbsup:
aboutime
I GOT THE HOOD DONE.
WHAT I DID WAS I PAINTED A BLACK STRIP FIRST, THAN I PUT MY LETTERING ON THE BLACK , TAPED OFF THE HOOD AND PAINTED IT WHITE.
THAN I PEELED OFF THE LETTERING TO SHOW THE BLACK. I KNOW THAT IT IS NOT RIGHT BUT LOOKS GOOD FOR ME
THE ONLY PROBLEM I HAVE WITH THIS TRACTOR IS ONE OF THE REAR HUBS IS WORN WHERE THE KEY IS.
Geno
Turned out really nice, you should be proud.   :handgestures-thumbsup:
JERSEYHAWG /  Glenn
That was quite an excercise in making do with what you have. Turned out very very nice. Thanks for sharing that.
Glenn
bo dawg
can you take a closer pic of your custom hood decal look?
