tommyg
Hydro Whine
tommyg
I'm sure this has been addressed before. I've been hauling around a trailer full of gravel around my yard quite a bit over last couple of weeks with my D180. No problems moving it around, but when I'm climbing a hill, or moving it from a stopped position, The hydro complains by whining as they typically do, but more  so because of the strain. My question is... Is this just something I should expect from a hydro system? If I'm running the tractor full throttle or close to it, do I run the risk of blowing something out if I push to hard? Will I stall the engine like a geared tranny?
I don't want to break anything, but maybe I'm babying it too much.
Edited by tommyg
pfrederi
Hydros whine.  Doubtful you will ever stall the motor, the wheels will slip first.  Hard pulling will raise the hydro temp thinning the oil which may exacerbate the whine noise.  If the fluid is clean and not too overheated you really won't damage anything by working it hard. Do you have a temp guage on your unit.)  However do not go forward to reverse with out coming to a full stop  and don't make jack rabbit starts/stops.  Some years D series had a buffer valve to lessen the effects of that kind of abuse.
cleat
I was wondering this as well for my Ford LGT165.
It has the eaton 1100 hydro coupled to a 2 speed transmission (I wish my 520's has the low range).
The Ford has a lot of whine. I have used both ATF and UTF in it with little change. Tractor works fine and actually quietens down when it warms up.
The 520's are very quiet and use 10W30 oil. Can I use 10W30 in the Ford ?
Cleat
SousaKerry
I would not recommend changing oil types as it is nearly impossible to get all the oil out.
Hydro's whine it's just there way like some people I know. :violin::rolleyes:
tommyg
Don't reallyl notice anything when I'm just mowing or doing light duty work. I've been hauling a trailer around the yard with a ton and a half of slag. More than I've ever called on the tractor to pull. Does it with ease. Just notice that whine a lot more under the heavy load and didn't want to blow anything out. Guess maybe I'm just being too cautious. I'd whine too if I had to lug a ton and a half of slag!
tommyg
I do have a temp gauge. Temp is not a problem. I believe mine does have the buffer valve if you're referring to the rectangular box right behind the right rear wheel.
flyovrcntry
A little cheese should help. Sorry,I couldn't resist :teasing-poke:
pfrederi
That is the buffer I mentioned.  if it isn't overheating I wouldn't worry too much about it.  May want to change the tranny fluid and filter more often. (I do not usually use synthetics but if you are going to be doing this heavy hauling for an extended period it might be a good idea.
Ed Kennell
:popcorn:
:text-yeahthat:    And a glass of  White Zinfadel     :popcorn:   :twocents-02cents:
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
    • Brandon Byers
      By Brandon Byers
      I know I'm half a year ahead of schedule!
      I picked this 1974 D-180 up early last year. It had a pretty hard life, and the previous owner gave his best attempt at keeping it alive. Hydro was strong so I serviced it and put it to work mowing all year. I decided if it would make it through the season then it would get some TLC. By fall it was burning about a quart of oil an hour but it made it. I have no clue how many hours are on it, every hole, bushing, bearing on this tractor is pooched. If you look closely, somebody used two 1" NPT Pipe Flanges to rebuild the mounting points for the upper 3 point cylinder. Hey it works!
      I rebuilt the steering gearbox and re-bushed the front axle along with making new spindles.
      I had the 482 Kohler bored .20 over (it was .10 over already) and gave it a rebuild with the intention of putting it back to work on snow duty.
      I then dawned on me that this tractor will be 50 years old next year - and these old D's are becoming harder and harder to find anymore. So I decided to customize it a bit and go for what a maybe a dealership would offer for a 50th anniversary model if Wheel Horse was still in business today (In another universe, maybe!)
      As D's aren't known for their looks - and I can't leave anything alone. I took approximately 2 Inches out of the grille and bezel.
      I updated most of the wiring and lights. Gave it a new set of Carlisle Ags along with Vredestein front ribs. It got a new seat and I painted all the accents aluminum.
      I patched, rebuilt the 48" deck and put new blades, wheels, and hardware on it. The Blade & 3 point scoop somebody adapted to it also got some attention.
      Lastly I stripped it most of the way down and painted it with IH red acrylic urethane enamel.
      I always forget to take pictures during my projects but here's a few:
      Before:
      After:
      Thanks for reading!!
    • Crazy Old Red Horse
      By Crazy Old Red Horse
      Barn find 1975 D180. 608 original hours. Tractor and 48” belly mower look to be still in their original paint. Rear 60” finish mower looks like it has had one coat of new paint added at some point. Open to trades. Please email me with any questions or for additional photos. 35 miles north of Pittsbugh.
