kudzu3 323 #1 Posted August 18, 2014 Looking for the flanged bushings for clutch engagement rod, part # 7879, # 14-94 0n the toro master parts viewer. Need two, but can make it work with one. Thanks. Share this post Link to post Share on other sites
squonk 41,638 #2 Posted August 18, 2014 You can still get them from Toro but not cheap. I just replaced 2 and need 4 more . I'm looking for another source Share this post Link to post Share on other sites
baerpath 517 #3 Posted August 18, 2014 bought bronze flanged bushings at ACE hardware. For the pedals but they had other sizes 2 Share this post Link to post Share on other sites
kudzu3 323 #4 Posted August 19, 2014 Squonk, if you find a source, please let me know,thanks Share this post Link to post Share on other sites
Shuboxlover 479 #5 Posted August 19, 2014 I may have some....let me look Share this post Link to post Share on other sites
GDSX2 1 #6 Posted August 19, 2014 Google them they are $9.82 online I have 5 but would want the same price the are nos out of a old dealers parts I bought Share this post Link to post Share on other sites
squonk 41,638 #7 Posted August 19, 2014 I checked with McMaster -Carr and measured the 1 new one I have left. Seems to be an oddball size. If McMaster doesn't have it might be tough to find any at another supplier Share this post Link to post Share on other sites
Martin 2,133 #8 Posted August 19, 2014 they turn up on ebay every now and again.there is a listing now 2 for $15 free ship, not as cheap as i have found them though. Share this post Link to post Share on other sites
kudzu3 323 #9 Posted August 19, 2014 Wow, toro is really proud of those things. I really need these before I can proceed with my build. I checked ebay and can't find any. Thanks all. Share this post Link to post Share on other sites
GDSX2 1 #10 Posted August 19, 2014 What model tractor are you working on Share this post Link to post Share on other sites
Martin 2,133 #11 Posted August 19, 2014 Just looked and they are still there....... search wheelhorse 7879. Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
kudzu3 323 #12 Posted August 19, 2014 Thanks folks...I made one. A friend gave me a brass bushing much too large, but the center was the correct diameter. I chucked it in a drill with a rag wrapped around a large drill bit to keep it tight and used a file and sandpaper to shape it, turned out perfect. I appreciate all the help. 1 Share this post Link to post Share on other sites
Trouty56 567 #13 Posted August 20, 2014 If these are those 1/2 ID...9/16 OD or whatever...I used a 5/8 OD and drilled the holes out to fit...works and much cheaper.... 2 Share this post Link to post Share on other sites
squonk 41,638 #14 Posted August 20, 2014 That's not a bad idea Bob. A 5/8 bit would be about as much as a bushing from Toro. Prolly a couple of bucks more and you'll have 4 bushings Share this post Link to post Share on other sites
Tankman 3,520 #15 Posted August 22, 2014 For thrust washers and flanged bushings I usually order online. Price 'n delivery, excellent. http://www.qbcbearings.com/BuyRFQ/SleeveB_StandardS_F_SB_I.htm Share this post Link to post Share on other sites
Tankman 3,520 #16 Posted August 22, 2014 (edited) The thrust washers are excellent quality and various thicknesses. I use 'em on my front axles. Edited August 22, 2014 by Tankman Share this post Link to post Share on other sites
squonk 41,638 #17 Posted August 22, 2014 That's a good site but the size needed is not listed. I have 1 new 7879 here and I measured an ID of .498 or 1/2" and an OD of .56. Their smallest OD is for 1/2" is .62 which is 5/8' which is what I'm finding everywhere Share this post Link to post Share on other sites
Wayne 28 #18 Posted September 17, 2014 I was looking through the hardware bins at TSC, and found they carry several different sizes Share this post Link to post Share on other sites
MikesRJ 552 #19 Posted June 7, 2015 (edited) They say necessity is the mother of invention, and I will freely admit that this one falls under the heading of; "dumb things you figure out while restoring old tractors". While pulling the tractor apart I noticed that all four flange bushings (2 for the fender pan pivot point, and 2 for the manual PTO handle {WH P/N: 7879} ) were almost completely gone. I figured they were a common part and I'd buy four to replace them and be done with it. Well, they are an available part ... if you want to pay $10 a piece for them at Toro. While looking for a couple of odds and ends at Tractor Supply, I saw these "1/2" Axle Cap Nuts". I knew the inner diameter was 1/2" to accept the 1/2" rod, I could grind off the cap, and those barbs could be moved or ground off, to make the flange bearings I needed. Plus they are exactly the same OD as the pressed holes in the Dashboard Riser and Fender pivot bracket. They worked like a charm and they're only $1.79 per 2 ea. I have included pictures below. Note the cap is ground off and the tabs pressed back into the body. I held the cap with a pair of needle nose pliers and used my upright belt/disk sander to grind the cap off. Edited June 9, 2015 by MikesRJ 5 Share this post Link to post Share on other sites
squonk 41,638 #20 Posted June 7, 2015 I'm going to TSC today anyway. Gonna have to pick up a couple of bags. That is if the have them. Drawers are half empty 1 Share this post Link to post Share on other sites
AMC RULES 37,141 #21 Posted June 7, 2015 10 packs on Ebay too. Share this post Link to post Share on other sites
squonk 41,638 #22 Posted June 7, 2015 Went to TSC. Of course they only had 1 bag. Rest of the drawer was packed full. I also needed 20 3/8 nuts. They had 21 Share this post Link to post Share on other sites
953 nut 56,147 #23 Posted June 7, 2015 Went to TSC. Of course they only had 1 bag. Rest of the drawer was packed full. I also needed 20 3/8 nuts. They had 21 Mike, they had 22 nuts, you were there! 2 Share this post Link to post Share on other sites
squonk 41,638 #24 Posted June 7, 2015 I'm not 3/8' I'm metric 1 Share this post Link to post Share on other sites
