meadowfield 2,595 #1 Posted August 17, 2014 I'm confused... I bought an 8 speed transmission from a 312-8 that was broken for spares. I couldn't see the axles as they had moved inwards, upon removal and splitting they are 1" and it's got a 4 pinion diff. Did they fit these to 300 series or was it a swap by a past owner? Share this post Link to post Share on other sites
racinfool40 202 #2 Posted August 17, 2014 all the 308-8's 310-8's and alot of the 312's were the 1" axle 4 pinion 8-speeds... 1 Share this post Link to post Share on other sites
stevasaurus 22,882 #3 Posted August 17, 2014 The 8 speed transmissions come in 3 kinds. the 5091, 103907,103916 and 103918 are 8 pinions with 1 1/8" axles...the 5073 is a 10 pinion, limited slip with 1 1/8" axles,,,and the 5086 had 4 pinions with 1" axles. The 5086 trans was used in the 1972 Raider 8 and 10...and in the 1973 8 and 10 HP no name horses. The brake drum is mounted on the cluster gear shaft in all these transmissions. Share this post Link to post Share on other sites
Lagersolut 681 #4 Posted August 18, 2014 The 8 speed transmissions come in 3 kinds. the 5091, 103907,103916 and 103918 are 8 pinions with 1 1/8" axles...the 5073 is a 10 pinion, limited slip with 1 1/8" axles,,,and the 5086 had 4 pinions with 1" axles. The 5086 trans was used in the 1972 Raider 8 and 10...and in the 1973 8 and 10 HP no name horses. The brake drum is mounted on the cluster gear shaft in all these transmissions. I know this has probably been ask before ( probably many times ) but what are, if any, the do's and don'ts with the 1 inch axle tractors compared to the 1 1/8 as far as pushing snow , plowing garden etc ? Also wondering why the 300 series were produced with the smaller axles . Share this post Link to post Share on other sites
Racinbob 11,238 #5 Posted August 18, 2014 I really don't think things like you're mentioned are any problem with the 4 pinion, 1" transmissions. One of my tractors up north was a 84 GT1100 (the gray ones). It was the tractor I used to push the snow off my 800' of driveway. We had some nasty snows too since we were right in the lake effect area off Lake Michigan. Since it was more fun to push snow the only time I got the 16hp out to blow it was when it was just too much. I also plowed (dirt) with it. The tiller went on the 16hp because the axle hitch was different on mine. As far as why they made them. I'd say is was just a cost thing. 2 Share this post Link to post Share on other sites
stevasaurus 22,882 #6 Posted August 18, 2014 These are all "garden tractors" and as such are very capable of moving snow, plowing a garden and anything else that they were designed to do. When you start making pulling tractors out of these horses...that is when you get into the number of pinions and the diameter of the axle. 1 Share this post Link to post Share on other sites
Lagersolut 681 #7 Posted August 18, 2014 Thanks for the replies , I'm getting ready to fit my 310-8 into the worker of the bunch ( since restoring the C-101 in my AV ) I never even gave the smaller axles a thought until I read this thread . It's going to share mowing duties with the 315-8 plus plowing and pushing snow - figured I better ask. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,104 #8 Posted August 18, 2014 Here are some more that used the 5086. Notice the 16hp models 1979 C-161 8-speed model 91-16K8011979 C-161 Twin 8-speed model 91-16B8011979 C-161 Twin 8-speed model 91-16B8021980 1100 Special model 01-11B8031981 GT-2500 8-speed model 01-11B8041982 SB-421 8-speed model 01-11BH011982 SK-486 8-speed model 01-16KH011982 GT-1142 8-speed model A1-1142011982 GT-1642 Twin 8-speed model A1-1642011983 GT-1142 8-speed model A1-1142021983 GT-1642 Twin 8-speed model A1-1642021984 GT-1100 8-speed model A1-11B8011984 GT-1600 Twin 8-speed model A1-16B801 Garry 2 Share this post Link to post Share on other sites
meadowfield 2,595 #9 Posted August 19, 2014 Awesome work guys, my C-161 has a 103916 as I've borrowed that transmission for project bendy. This transmission will be rebuilt and become the front trans for bendy. I'm sure it's more than up to the job! Mark 1 Share this post Link to post Share on other sites
can whlvr 993 #10 Posted August 20, 2014 so I have both 1 inch and 1 1/8 tractors,i find the 4 pinion 1 inch axle pushes snow better than the 1 1/8,dont know if its the tires or what but the 1 inch works great,ive had it since new in 1986,and its been amazing and done a lot of extreme hard work Share this post Link to post Share on other sites
