heysavoy
Belts for 312-H
heysavoy
PLEASE!!!! can someone can help me find the part number for a belt I need before I go crazy?
I just bought a Wheel Horse Classic. I believe the year is 1990 and the tractor model # is 31-12KE01 . The model # on the deck is 1548SC02. The belt that runs from the mower deck to the PTO to the two small front pullies located toward the front of the tractor broke the first time I used it.  I was then sold a drive belt (I believe is what it's called) and that part number was 7473 but it can't be the correct belt because it is way too short. What does that belt go to? Does it sit horizontally on the top of the deck?  Are there only two belts total for this tractor?
I have looked at every website diagram I can find and do not see the belt I need.  I've been given about 5 different numbers and can't afford to waste $$$ again ordering the wrong one. I also downloaded the manual but all it tells me is to "install belt in inner grove if using the mower" (which is what I am using (mower deck) since I don't have any attachments.
Can someone please help me? Thanks so much to whoever responds!
Forest Road
According to Partstree.com 7473 is your transmission drive belt.
Go to that sight and enter your deck model #. It does list both belts.
New belts typically last several years. It's money well spent.
heysavoy
I'm sorry but I honestly don"t know very much about tractors. Is the belt I described in my post that I need the transmission drive belt?
gwest_ca
7473 is the drive belt for the same model tractor with an 8-speed gear transmission.
The hydro transmission model you have uses transmission drive belt 108501.
The parts lists are often shared by similar models and the online versions often fail to identify what model uses what. In this case the belt charts are the best to use.
Tractor drive belts
Mower deck belts
The belt dimensions are on the last pages of each file.
Garry
heysavoy
i do have the hydro stay model so I'm good on transmission belt
but can't locate deck belt on parts tree using deck # 1548SC02 and 21675. Any idea what the deck belt # would be?
1995 520H+96+97
Click on the link below.
https://www.partstree.com/parts/toro/mower-deck-assemblies/15-48sc02-toro-48-side-discharge-mower-deck-1990/side-discharge-mower-42-48-in-107-122-cm-vehicle-identification-number-15-42sc02-15-48sc02_2/
Item #41,  v belt 94-2501 or 102742
Make sure the 3 blades spin freely and are sharp. Inspect the 3 spindle housing, they should not be broken or loose.
Make sure the deck is mounted correctly ,in the mid mount attach a matic, If it is not, the 102742 v belt will be broke again.
Edited by 1995 520H+96+97
gwest_ca
Mower deck drive belt 102742 replaced by 94-2501 (1/2" x 103")
Mower deck spindle belt 1594 (1/2" x 107.21")
More info here. Click on the picture
Garry
squonk
Napa # 6378
heysavoy
Thank you SO MUCH for the link above!!!  So to summarize, I only need TWO belts. The transmission drive belt 108501 since I have the hydrostat transmission model and then the v belt 94-2501?  Another "poster" mentioned Spindle belt 1594 (1/2" x 107.21") which confused me.
squonk
Hydro drive belt is Napa 5l820W
Deck drive is Napa 6378
1995 520H+96+97
I only listed the pto (mule drive) belt as that is the belt you stated was broken.
https://www.partstree.com/parts/toro/mower-deck-assemblies/15-48sc02-toro-48-side-discharge-mower-deck-1990/rear-side-discharge-mower-42-48-in-107-122-cm-vehicle-indentification-number-15-42sc02-15-48sc02/
Item # 1  belt # 1594 is the spindle belt.
The Toro owners manuals for all equipment has all this useful information.
heysavoy
I really appreciate you helping me. And I'm sorry but I'm still confused because under the link you provided above, when I look under "more details" for Toro Part #1594 it doesn't list my specific deck #15-48SC02.     Thank you!
gwest_ca
The "More Details" only list a portion of the models it fits. Notice those that are listed are mostly 48" decks. Where a 42" deck is shown that deck shares a parts list with the 48" deck so ends up included but not the correct belt for a 42" deck.
Garry
  • Similar Content
    • Bill D
      By Bill D
      Found these at Lowe's.  Same belts as TSC, just different packaging.  The 86" I got was on clearance and is not being stocked anymore.  They had sizes from 87" to 109" in 1/2".  Not a lot of 5/8" belts that would be useful for our tractors.
    • heysavoy
      By heysavoy
      https://vimeo.com/user167505007/review/680209151/31e34aa31f
      I own a 1990 Wheel Horse Classic Model #31-12KE01. While removing the rear tire I noticed what I've posted in this video link. I assume that's my brake wheel (product name is problem wrong 😄).  Does it look normal as it appears loose to me? The only brake issues though I've had is the tractor rolls when on an incline which I thought was a parking brake problem. So looking for some thoughts.
    • Ifixoldjunk
      By Ifixoldjunk
      I just bought a deck for my 310-8, it’s a 42inch rear discharge, it came with a complete parts tractor, but I need new belts for it. Does anyone know what size belts I need?
    • Tim Fenn
      By Tim Fenn
      I've just acquired a renovated C125 but unfortunately the drive belt got snagged with the mower deck belt (maybe because of incorrect fitment?). It looks like I'm on a steep learning curve! I've been trying to find out which belt to buy as a replacement. The belt I've just taken off is 94 inches but  according to the parts manual I need a Toro belt part number 94 2501 which is 103 inches? The mower deck is a 42in rear eject. It's funny that the Toro belt has 94 2501 as the part number but is 103 inches & I apparently need a 94in belt? Any ideas?
    • CTR
      By CTR
      I have a 312 8 Wheel Horse that i have
      Had for 16 years and thé belts are thé ones that came on thé tractor.I am having problèm finding thé belts. Any hélp would be great.
