fretscha
400 series rims on 300 series
fretscha
Hello guys,
i have found 400 series rims on ebay. Can i mount them on my 316-8 without problems? I have ordered 23x10.50-12 for the rear, now i want bigger rims at the front for a better design.
regards from germany
Jens
traktorkidd7/30/93
You will also need to get the upgraded front spindles too or else your tractor will be set high in the front
fretscha
Normally i have 22x8.50-12 on the rear rims. with the 23x10.50-12 the back is lifted so it will be on the same hight with the 400 rims, or not?
traktorkidd7/30/93
Maybe you wouldnt have to but I would :banghead:
Curmudgeon
Hard to say.
For instance, Carlisle Turf Savers:
22x7.50x12.... 21.8" tall
22x9.50x12.... 21.3
23x8.50x12.....23.1
23x9.50x12.....23.2
23x10.50x12.... 22.6 or 22.8 depending on number of plies
As you can see, even within the same brand and style, sometimes tires are taller, sometimes shorter than their listed sizes. Throw in different brands and styles and it's a wonder our little tractors ever set level.
For all practical purposes, we'll never notice the small differences with a tire size, but changing wheel diameters is a different matter.
Curmudgeon
Here's another tidbit....
Titan Super Turf, 2-ply
23x10.50x12..... 23"
24x12x12..........23.4"
LESS than half an inch between a 23" tire and a 24"
Edit:
24x12x12 - 4 ply, 23", SAME as a 23" tire of the same brand, and shorter than other brands 23" tires!!!!!!!!
fretscha
the tires on my 316 are 16x6.00-6.
the tires on the 400 are 16x6.50-8.
So i think the height will not change so much. Just the rim diameter change, the tire height doesn
kpinnc
  Quote
I put the larger front wheels/tires on my 310, and do not have any problems. Feel free to judge for yourself:
The nose is lifted maybe 1/2 inch, but this does not affect any decks, or implements I would use in any way.
I have never understood where the idea of using 8 inch wheels set tractors too high. The 400 series use the same front axles and spindles as a 300, so how does it make them higher?
The sole purpose of using the 6 inch rims on a 300 series was to allow clearance for the 37 inch SD decks. If you use one of those with 8 inch front wheels, you're gonna have issues- When you turn left (all the way to the stops), the left wheel will contact the deck. Use a 36 RD or anything up to a 48 SD, and you'll be fine. Just not the 37 SD...
Kevin
fretscha
Thanks a lot, Kevin!
That was the answer i has needed. So i hope they will not give to pricy. :banana:
fretscha
The Ebay Auction is ended. I have bought the rims. I hope the USPS is fast in shipping to germany. Then i will make thiswheels on the rims and thiswheels on the rear. What do you think about that?
C-Series14
Wunderbar!!! That thing will look awesome! :banghead:
Craig Arndt
When you get them, make sure you show us! :banghead:
Irv
I did it on my 310-8 and 312-8 with no problems. Just had to adjust the mower deck front height. And the 310 has the 37" sd deck.
fretscha
Hello,
today the rims were coming. Now, it is possible to see the difference
That is the 300 series design!
And now the 400 series design!
The height isn
