scotty 252 #1 Posted August 12, 2014 Another problem with my wheel horse b60 the brake band seems to be touching the brake drum when i push the tractor forward. When i started to ride it the whole tractor came to a stop. adjusting the nut seemed to have to effect. Share this post Link to post Share on other sites
rmaynard 15,633 #2 Posted August 12, 2014 (edited) Unless there is a problem such as the brake lining coming loose from the brake band, or a foreign object in the brake, you should have enough adjustment in the nut and/or the trunnion to adjust the brake pedal to a comfortable position, have proper braking with no drag, and be able to lock the parking brake. Edited August 12, 2014 by rmaynard Share this post Link to post Share on other sites
scotty 252 #3 Posted August 25, 2014 It ended up being that the brake band was broken. Share this post Link to post Share on other sites
rmaynard 15,633 #4 Posted August 26, 2014 Thanks for the follow-up to let us know. 1 Share this post Link to post Share on other sites
scotty 252 #5 Posted August 26, 2014 Quick question what could i use as a substitute for a brake pad? napa told me that they dont sell wheel horse brake bands. Share this post Link to post Share on other sites
slammer302 2,155 #6 Posted August 26, 2014 I hand the same problem with my b-60 I used black silicon to glue it back on the band I know this isn't the best fix but it still working Share this post Link to post Share on other sites
